Thread: Line pen tool with grid snap, can not make a poly.
    14,677
    Just noticed...
    when I create a polyface with the line pen tool and using vertex snap drawing the basic shape and finally making a poly when I close the line "loop" that is working normally, but when I use grid snap..it doesnīt work.
    Your input on this please
    the pen tool isnīt an option..so donīt go about to suggest that.
    Edit..I may get away with using merge points, with some mm tolerance, then in polymode select all those edges and use edge to poly to get a polyface, it seems the grid snap may prevent from actually snapping to the vertex exact postion and instead use the grid, then again when I use the grid..you would expect the line pen to put the vertex exactly based on the grid..some tolerance issue?
    I would rather have it create the polyface directly once the line pen is completed..with grid snap on.
    Lightwave modeler 2015 32 bit.
    Itīs the same in lightwave 2018 by the way.
    14,677
    weird..somehow I got it working with grid snap, might be some grid settings perhaps.
    And not...something is happening when I used fixed grid snap.
    Super Member Snosrap's Avatar
    Aug 2004
    Ohio, USA
    4,923
    Let me know if you can make use of this tool with a Wacom tablet. I can't.
    14,677
    Quote Originally Posted by Snosrap View Post
    Sure...send a tablet to me then I will check Thanks for the heads up...maybe I can borrow a cheap one from my niece and check, but thatīs a cheap one and not wacom.
    Amazing...I still havenīt got me one, hopefully I buy one before I retire.
    Jan 2005
    Colorado Springs
    1,779
    Line Pen tool completes the polygon in all Grid Snap cases for me in LW 2018.0.3. BUT, I have to be very careful that the "vertex" snap hint is shown before clicking to start a new segment. It's easy, especially with a very small Fixed Snap grid granularity (e.g. 1mm) to get off of the end vertex of the previous line segment.
    I also don't have a tablet to test with (well, I have an OLD serial port Wacom). Again, with small snap values, it's easy to miss the end vertex of the prior line segment.
    mTp
    14,677
    Quote Originally Posted by MonroePoteet View Post
    mTp
    Thanks for the heads up on being careful, though I thought I was...I still need to work much more with it and eventually track down exactly what is causing it.
    Aug 2004
    Ohio, USA
    4,923
    I think the overall action of the tool is wrong in regards to what it does on a mouse up. It should have been a Pen tool on steroids, but they made it too different in its function from the Pen tool. Another great potential that missed the mark.
