Thread: FiberFX cluster texturing difference
    Super Member Boris Goreta's Avatar
    Zagreb, Croatia
    1,347
    I've textured fibers with a color noise so each fiber would be colored differently. It works good with a cluster value of 1 but when I raise cluster value to 2 patches of fibers get the same color+still some randomization but the constant color is obvious for each underlying polygon which is not desired. How do I work around this problem ?
    patch.rarClick image for larger version.
ID:	140726Click image for larger version.
    Zagreb, Croatia
    1,347
    I'm so lonely ...
    Jan 2005
    Colorado Springs
    1,782
    I'm unable to unpack your .rar file. I use 7Zip for compression / decompression, but it won't open your uploaded file. Sorry!
    Also, what version of LW are you using?
    mTp
    Video Junkie Vong's Avatar
    Eagle Mountain, Utah
    301
    mTp, try updating to the latest version of 7Zip. I'm able to extract Boris' file just fine with the latest version.
    Curtis Rhoads
    Desktop: Win10 x64 | i7 3.4GHz | 32GB RAM | GeForce GTX970
    Laptop: Win10 x64 | i7 2.3GHz | 8GB RAM | GeForce GT650M
    Desktop: iMac | i7 3.5GHz | 8GB RAM | GeForce GTX 780M
    Jan 2005
    Colorado Springs
    1,782
    OK, thanks, yes the upgraded 7zip opened the archive.
    I don't see the patch problem in LW2018.0.2, BUT I'm not running Octane. Loading the scene I had to say "No" to requests to load-from-disk for Octane nodes (Octane Diffuse Material and Octane Texture Image). Someone else running Octane will have to test it, but I'd say it's the Octane shaders.
    Native LW2018.0.2 render (plain gray fibers):
    mTp
    Zagreb, Croatia
    1,347
    You have to apply noise texture to fibers. Here is how it looks in native LW renderer, the same :
    Here is the native LW scene:
    patch.lws
