Results 1 to 8 of 8
Thread: Tricaster Mini Video Feeds
    Feb 2018
    Rice
    4
    Since recently updating two of our Tricaster Mini HD-4 units the video feeds are distorted after startup. On one unit an error came up asking to manually change the "expected HD input Capacitance value?" (Sorry this was passed on by another user) Oddly if you leave all HDMI inputs unplugged then plug them in after the Tricaster has loaded then plug them in everything seems to work just fine. Cable length seems to not be the issue as high quality 3 foot mini HDMI to HDMI cables cause the same issues.
    Any Help would be appreciated.
    Sep 2008
    usa
    21
    this might be a similar issue-
    launch tricaster mini and plug in HDMI sources... signal all good
    quit out of a session and launch another, HDMI sources do NOT appear unless disconnected and re-connected -after that signal is good
    this is the most current software release
    each session matches camera source resolution
    anyone else seen this?
    thanks
    Feb 2018
    Rice
    4
    That also happens occasionally for us as well. We are using mini HDMI to HDMI cables that up until this update have been working flawlessly.
    I have a different yet similar issue. Turn on studio cameras using SDI to SDI to HDMI converter boxes, HDMI into Mini. Launch session and everything is perfect but then when a camera is turned off while the session is still open, the Output and Preview monitor blinks blue. Keeps blinking even if I turn the cameras back on. Have to quit the session and reopen it to get the signal back. It’s a persistent issue on TriCaster Mini running the most current standard edition software.
    Jeremy Brandt
    TV/Video Teacher
    Voorhees High School, NJ
    http://www.VoorheesTV.com
    TriCaster Mini - Standard Edition
    TriCaster Mini Control Surface
    Primary Cameras - JVC GY-HM750
    Jun 2012
    peru
    342
    do you have the latest version of software?
    Gear Used:
    Tricaster: All 3Play:440
    Cam: JVC GY-HM600, GY-HM150U
    Facebook
    Twitter
    Feb 2018
    Rice
    4
    Yes this has only been an issue since updating to the newest version of the software.
    Apr 2017
    Massachusetts
    134
    I blame HDMI.
    TriCaster TC1 #1
    TriCaster TC1 #2
    NC1 Studio I/O Module
    Video Nerd
    Feb 2018
    Rice
    4
    Any particular concerns about the HDMI? We are not having any issues with any of our other tricasters using HDMI at this time. Only on units with updated software. I know there are other more robust video standards but for many schools using existing cameras that support HDMI is a must.
