Thread: Invert subtract boolean
    Jan 2009
    Norway
    174
    Is there a feature or plugin in Lightwave modeller to invert-subtract? As an example, draw a box in a bg-layer and after a boolean command, only keep the areas inside the box in the fg layer?
    Time Traveller Andy Webb's Avatar
    Hertfordshire UK
    2,127
    Yes it's called "Intersect", Shift + b to bring up the Boolean panel and chose Intersect and that, if I understand you correctly, will give you what you want.
    Andy Webb
    Intel core i7-3820 3.60GHz
    Asus P9X79 Deluxe motherboard
    GeForce GTX 660
    16 Gb RAM
    Windows 10
    7,728
    Quote Originally Posted by mikkelen View Post
    Isn't such operation called intersect.. ?
    Construct > Combine > Boolean > Intersect mode.
    LightWave Plugins
    Jan 2009
    Norway
    174
    Thank you, it's almost the same, but it seems to add some geometry from the background layer, and not just a clean cut and subtract.
    May 2017
    Lampertheim, Germany
    113
    Hello mikkelen,
    are you using LW 2018? If so, than please use the Feedback Agent to Report the boolean issue. I did so. Have a look at the thread "bug in 2018?" in the "LScript Scripting" forum, it seems that you have the same troubles with booleans than me. The strange faces also appear in building a complex polygon from an array of points with the "p" command, so it may be that the issue isn't in the booleans, may be it is in detection of forms.
    http://forums.newtek.com/showthread....50-Bug-in-2018
    Regards,
    KANUSO
