Results 1 to 10 of 10
Thread: Always broadcasting NEWTEK-CONNECT Wifi SSID?
    Live Streaming pdxJoe's Avatar
    Sep 2008
    Portland, OR
    172
    I've setup the spark to connect to my access point.
    Yet, it appears that it is still broadcasting the SSID "NEWTEK-CONNECT". Is this how it works for everyone... all the time?
    I work at events where it is poor taste to broadcast an SSID.
    Let me know if this can be turned off or if it is always on.
    Cheers!
    joe
    Blaze Streaming Media
    www.blazestreaming.com
    Feb 2017
    Plymouth, MA
    48
    Joe,
    I saw this post and was hoping someone replied. We have the same issue. Have you found the solution?
    Apr 2017
    Massachusetts
    181
    Does it still broadcast an SSID if you configure it to connect to a wifi network? Even if the network isn't accessible, it should be searching for it rather than defaulting back to being an ad-hoc hotspot
    TriCaster TC1 #1
    TriCaster TC1 #2
    NC1 Studio I/O Module
    TriCaster Mini SDI Advanced #1
    TriCaster Mini SDI Advanced #2
    Video Nerd
    Oct 2015
    Oskaloosa, IA
    10
    We've been running across this, too. We've got two Sparks and they are always broadcasting SSIDs, even when connected to our WiFi.
    I am surprised by the lack of options in the firmware.
    The latest firmware should resolve this. What firmware are you running?
    http://new.tk/NCSInfo
    Key Accounts Sales Engineer
    Oct 2015
    Oskaloosa, IA
    10
    We're using the latest Spark firmware and they still broadcast SSIDs even when connected.
    Also, I'm curious if there is a way to prioritize connecting to 5GHz (or 5.8, or whatever it is) instead of 2.4GHz. We've noticed that it is suggested to connect to 5GHz, but even when our connect to a 5GHz network they still think they are on 2.4GHz, despite the access point being about ten feet away. They still send a signal that works, though.
    I've also noticed that I cannot for the life of me find where to get a MAC address for the Sparks, in either Windows or macOS browsers viewing the interface. I don't have the field I've seen in some screenshots.
    The biggest problem, however, is that our TriCaster will not load a session if a Spark is connected to the wireless network. We've been using them mainly with another switching software and they work great, so it makes me wonder if it is a compatibility issue. We are currently using Advanced Edition build 4-0-170313C after the latest (at the time) version had catastrophic stability issues during an event, which I see have hopefully been addressed. So the question is, what NDI/HX build should I be using with our AE build, and where do I download it? I'd like to try that before installing the newest version of AE. We have an event at the end of this week and I'd love it if I could reinstall and older version of the NDI tools and have the Sparks work, rather than installing the new AE and possibly having to roll back yet again. It comes down to not having enough time.
    Thanks for the info,
    Adam
    Sep 2005
    NewTek
    1,682
    Adam you need to update your TriCaster software to the latest version of Advanced Edition which is 5-1-180911. We no longer even offer 4-0 versions of TriCaster for download.
    Zane Condren
    NewTek Inc.
    new.tk/call
    Oct 2018
    NL
    7
    Even with last week's firmware (3.99.1911) the Connect Spark is Broadcasting its SSID.
    Is there any way to disable this?
    Thanks & kind greetings.
    I was incorrect in my previous message.
    Mar 2019
    Melbourne
    14
    If you blokes pull out a WiFi scanner tool (there's a good one for Android devices called,... "WiFi Analyser,.." ) and watch what happens when the Spark is assigned to a network, you'll see that 'Newtek-Connect' labels SSID will jump to the channel of the assigned network.
    I'm betting there's supposed to be a WiFi Mesh option, where multiple Sparks can extend and share the network, but I haven't spotted it in the documentation yet.
    If that's the case, it would probably be better for that function to adopt the SSID of the assigned network.
