Results 1 to 1 of 1
Thread: Layout Command Port Python Package Bug
    Hi All,
    I was exploring some of the new Layout Command Port features and ran across a bug when following the Python Package video tutorial from the new documentation:
    https://docs.lightwave3d.com/display...8/Command+Port
    I get the following error after cd'ing into D:Program Files\NewTek\Lightwave_2018.0\support\python and executing the Python commands from the tutorial that should launch a new instance of Layout:
    Code:
    PS D:\Program Files\NewTek\LightWave_2018.0\support\python> python
    ActivePython 2.7.10.12 (ActiveState Software Inc.) based on
    Python 2.7.10 (default, Aug 21 2015, 12:07:58) [MSC v.1500 64 bit (AMD64)] on win32
    Type "help", "copyright", "credits" or "license" for more information.
    >>> from lwcommandport import layout
    >>> l = layout.Layout()
    Traceback (most recent call last):
      File "<stdin>", line 1, in <module>
      File "lwcommandport\layout\__init__.py", line 126, in __init__
        raise Exception(msg)
    Exception: LightWave does not appear to be installed on your machine!
    The solution is to edit the layout\__init__.py file and change line 110 from:
    ver = kwargs.get("version", "2016")
    ...to...
    ver = kwargs.get("version", "2018")
    At that point the LightWave install is found and Layout launches as it should:
    Code:
    >>> l = layout.Layout()
    Launched Layout process with args "--command-port=LW_46A738BB"
    I've filed a bug report but maybe this will help someone else in the meantime.
    Cheers,
    -Kevin
