Thread: Disable WiFi?
    Jun 2010
    Green Bay, WI
    41
    Disable WiFi?
    Is there a way to disable WiFi on the Spark, and if so, how?
    If it can't be disabled, is it safe to operate it without the antennas? I am hardwired in and space is a factor in my Spark setup, so I'd like to use it without the antennas.
    I use mine wired and without the antennas all the time. You will still see some WiFi even without them, but I just don't setup the WiFi to connect to anything.
    Key Accounts Sales Engineer
    Jun 2010
    Green Bay, WI
    41
    OK, I just wanted to confirm that this would not harm the unit. I know in some cases, using a transmitter without the antenna on it can be bad for it.
