Thread: VMC - Dante installation failure
    Apr 2017
    Belgium
    20
    Is any way to install DANTE sound card on VMC system ?
    I've tried with 'run as administrator' without soling my problem .
    according log file , there is a problem with MSI packager.
    Any idea ?
    thanks
    Apr 2017
    Belgium
    20
    Solution to solve it : install older version of DVS like 2.75 before the last version. work for me after support call.
    Dec 2007
    Germany
    172
    Hi!
    Just about to install Dante Soundcard to VMC.
    Can someone confirm that all issues are resolved and actual version v4.0.4.4 is fine to use?
    Many thanks!
    Best regards,
    Matthias
    Sep 2005
    NewTek
    1,682
    Yes, installing 4.x is fine, I am unaware of any issues with it compared to 3.10.
    Zane Condren
    NewTek Inc.
    new.tk/call
    Sep 2009
    Los Angeles, CA
    214
    this isnt needed if Premium Access has been purchased correct?
    Gear Used:
    TCXD 8000
    3Play 4800
    VizRT IP 2-Channel
    Panasonic HDX 900 Cameras
    NDI Connect Pro
    Graphic Outfitters ScoreHD
    Sep 2005
    NewTek
    1,682
    Premium Access does not install or license Dante Virtual Soundcard. Ideally, you will install DVS, activate your license then reboot your system before licensing Preimum Access.
    Zane Condren
    NewTek Inc.
    new.tk/call
