Results 1 to 15 of 15
Thread: polygon reduction tool
    Since I've upgraded, I've lost the use of qemmloss 3, which I found to be an invaluable tool for reducing the poly count of some models. Can anyone recommend a good tool that's not too expensive? Ive tried mesh lab and instant mesh, but
    haven't had much success with either. thanks
    PLG plugins have simplify mesh plugin.
    Thanks, I'll check it out.
    Angry Mac User Otterman's Avatar
    May 2006
    England
    867
    Gemmloss isn't that just an early form of 'Reduce Polys +' found in the Construction tab. If in correct then it's still in 2015.3
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,670
    There's also Balancer ( and Balancer Pro ): http://www.atangeo.com/products
    Hope this helps
    the link on the lightwave plugins website is a dead end. How am I supposed to get the plg plugin if there's no website? Otterman, yes the version ni 2015 is qemmloss 2 I believe, (I could be wrong), but I'm sure it isn't version 3, which was what I've been using.
    OK, I found the website, which is true art support http://www2.trueart.pl/?URIType=Dire...ducts/Plug-Ins, but I don't see any tool for polygon reduction. Thanks daforum for the link, I've seen that tool before, and it looks pretty attractive right now. Guess I'll have to fork up the money for a descent decimator tool.
    Doesn't Zbrush have a reduction tool? I think its called Decimation master?? I'm looking for it now.
    May 2003
    Ohio
    773
    And another option for polygon reduction:
    https://github.com/wjakob/instant-meshes
    I wasn't aware of qemmloss 3 until this discussion but found the archived source on archive.org
    https://web.archive.org/web/20150524.../qemloss3.html
    thanks Ray, I have the qemloss 3 plugin, but it won't install on my machine. As for the others, I certainly appreciate your help with this. Thanks again.
    7,883
    Quote Originally Posted by jimiclaybrooks View Post
    Install 32 bit version of LW and try again...
    Oct 2007
    Belgium
    124
    It has been some years now but 3D Browser by Mootools has a pretty advanced polygon cruncher, don't know what it costs though
    meshlab?
