Results 1 to 15 of 20
Thread: point and poly normals
    ok heres a question how to get the point and/or poly normal
    Registered User mattbolton's Avatar
    KS, USA
    208
    From page 81 and 82 of the LScript Reference Manual.
    polynormal
    polynormal() returns a vector that represents the surface normal of the specified polygon.
    prototype:    status polynormal(polygon) (MD)
    status        boolean; if the operation succeeded.
    polygon       polygon id; the polygon to change.
    surface       string; surface name to which polygon is now assigned.
    I wish I could help more, but I've never used it myself. Knowing where to find the answer is half the battle.
    well duh
    heheh thanks missed that one in the docs
    Dec 2003
    Croatia
    5
    Here it is about point normals ... You get'em by adding all normals of polys that have 'guilty' point in it and divide it by polycount (numbers of polygons that have point You are interested).
    Here is a bit of code I used for this. Originally You can find it in a NormalBaker.ls that come with a LW if I can recollect for certain :
    // Get the point normal
    numPolys = size(vtxPolygons);
    for(k = 1;k <= numPolys;k++)
    workVal = polynormal(vtxPolygons[k]);
    pointNorm += workVal;
    pointNorm.x /= numPolys;
    pointNorm.y /= numPolys;
    pointNorm.z /= numPolys;
    numPolys is the array with poly IDs that have the point in it.
    You can get those by :
    pnt = points[i];
    vtxPolygons = pnt.polygon();
    Hope this helps.
    See ya! D
    Dec 2003
    Croatia
    5
    Ups! Sorry ...
    vtxPolygons is the array containing polygon IDs.
    Code Muppet evenflcw's Avatar
    Stockholm, Sweden
    2,642
    I think you might have been in a bit of a hurry, CroDude. Although someome lines are fine, some doesn't work and an important one was omitted.
    When working with normals it is of great importance that you normalize created values:
    PntNormal = normalize(AvgeragedSumOfPolyNormals);
    If you don't, operations such as pointmove(pnt, PntLoc + PntNormal*Distance), while still moving points along the normals, will not move them the correct distance! Normalizing ensures the values get the correct "scale".
    Dec 2003
    Croatia
    5
    Ups again! I forgot to cut it out !
    Here it is :
    // Normalize point normal vector
    pointNormN = normalize(pointNorm);
    That one goes to the end...
    Hope this helps.
    thanks for all the replys guys
    i just got back from a short vacation so ill get a chance to start on this asap
    thanks again and happy holidays
    well i looked at that normal baker plugin and that is really going to help alot and save me a lot of time
    one question i had is would i still need to normalize the point normal if i am just exporting the data to be used in a game
    well hit a big road block i guess i should have said from a layout lscript
    i have tried useing the code form this thread and from normalbaker
    but it seems like the polynormal function cant be accesed from layout
    any other ideas
    well so far the only thing i can think of for a work around is to have ascript that runs in modeler to find the normals of the points
    so the next question i hae is it possable to invoke a script from a script (im sure it is but never have done it)
    and is it possable to pass data between a modeler and layoput script
    well a easy out is to run normalbaker on the model first then save the model and search for the custom vmap type the normal baker looks for
    so that works for me until i found a better way or automate that part
    thanks again guys for the help
    i had a question as far as normalizing the normals
    and getting the normals for points does that take smoothing groups into account
    a better question would be how do you calculate a point normal while to include the smoothing angle as well?
    ok i found where and how to get the smoothing angle of a surface
    so the next question is how do you include the smoothing angle in the point normal calculation?
    or do you even have to
