Thread: quicktime 10fps?
    Member etobiason's Avatar
    Dec 2003
    Chicago, IL
    665
    quicktime 10fps?
    Using LW 7.5 on Mac OS X, I have tried twice to render an animation at 10 fps.
    For type I chose .mov, and under options I picked 10 as the frames per second.
    The first time there was no compression. The final rendered movie played at 30 fps.
    The second time I chose Animation compression and a key frame every frame, as well as 10 fps, and still the final product was a 30 fps movie.
    Any ideas?
    Quantum Mechanic danielkaiser's Avatar
    Riverside CA
    1,055
    Under Layout>Options>General Options, or the "O" key, set your frame rate there, this overrides the frame rate in Quicktime.
    Dan
    Daniel Kaiser
    "A mistake is always forgivable, rarely excusable and never acceptable." Robert Fripp
    AMD Phenom II x6 3.2
    Win 7 Pro x64
    8gig Ram
    Nvidia 640 GT 2Gb
    LW 11 x64
    Dec 2003
    Chicago, IL
    665
    forgot to mention
    I actually tried that already, too, and it didn't have any effect....
    Riverside CA
    1,055
    If you have Quicktime Pro or any other program that accepts image sequences, render your anim off as seprate frames (which is a good idea anyway) and set the frame rate in the app of your chooseing, should have said this before, it's the way most do it!
    then you can tweek the setup without having to rerender.
    Dan
    Daniel Kaiser
    Win 7 Pro x64
    8gig Ram
    Nvidia 640 GT 2Gb
    LW 11 x64
    Nobody render out as .mov or .avi (just people who works with web and needs a quick way to put their "masterpieces" on the web". If you are a serious 3duser I advise you to render out as an image sequence (.tiff or better .pic) ready to cook in Shake or your comp program, and here you can adjust the frame rate and export to .mov file. Other alternative is to import the sequence with Quick-pro and export as .mov.
    Enrico
    Dec 2003
    Chicago, IL
    665
    Thanks guys. I'll render pic sequences for low frame rate animation tests from now on.
    -e
