Thread: MDD size
    MDD size
    Does any one know if MDD files are kept in ram at all times or if there is some cache involved in it ? so far I have not hit the roof but with a few different characters, a few hundred frames and 500k points or so for each charcter per frame it can grow pretty fast.
    LightWave 2015.3 - Fantasy web comic: http://rustandmagic.se https://www.facebook.com/rustandmagic57/
    "I may not change the world but I'm gonna leave a scar" (Charlie Starr - Blackberry Smoke)
    Super Member Kevbarnes's Avatar
    Nov 2006
    Gloucestershire UK
    504
    I think the standard LW mdd reader reads from cache - if you use dpont plugins
    you have two options mdd_Pointer or mdd_Cache
    mdd_Pointer streams data per frame
    mdd_Cache loads data into memory used when you have clones using same mdd
    "one rig to rule them all"
    PC Spec: Intel i7 X980 3.33GHz | 24Gb | ATI FirePro V5800 | W7
    https://vimeo.com/kevbarnes/showreel
    https://littlstar.com/kevbarnes
    https://www.talenthouse.com/kevbarnes
    Ok, thanks, I will have a look at the DP plugins, lots of other cool things there anyway.
