Thread: How to rotate pivot in Layout
    Registered User Over's Avatar
    Nov 2016
    Virginia DC
    90
    Hello all, A little help if you can.
    I'm trying to rotate the pivot so the flap object rotates correctly. I rotate using the rotate pivot point tool, but when I go to rotate object again, the pivot stays looking forward. Am I doing something wrong?
    Edit: To explain a little more, I need the rotation axis to be paralel with the flap front edge. I rotate the pivot to that position, but when I change to rotate object, the pivot keeps looking forward like in the picture.
    Feb 2006
    england
    1,179
    I some times have this but cant think what it was off had, however I find the easiest way to do this is to rotate the flap so the front edge is at 90deg on the pivot in modeller and use the set pivot to put the pivot in a better location (eg select the poly at the front of the flap and use the centre pivot command) beforehand, then just rotate it back in layout, and that way it avoids any problems caused by IK or Coord systems.
    Intel i7 5960X Extreme, Asus Rampage V extreme, 3x 4gb NVIDIA Geforce GTX970, 32GB DDR4 2666 corsair dominator
    Nov 2003
    jersey
    5,763
    About the 1min mark
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Nov 2016
    Virginia DC
    90
    Thank you very much for your answers. I can have a good result using bones or nulls, but want to know if there was the possibility of direct transformation modifiying only the pivot.
