Page 1 of 4 123 ... LastLast
Results 1 to 15 of 57
Thread: Fiber FX - Weird behavior
    Living over there... MAUROCOR's Avatar
    Jun 2004
    Sao Paulo Brazil
    2,434
    Hi, guys.
    I start creating a lipsync to this character and for some reazon the hair is acting really weird.
    There is no dynamic applied and the hair start moving.
    I already spent a lot of time on this and just I can not fix it.
    If you look carefully you will see that even the hair of the ears and nose is moving.
    Someone may have an idea why is it happening?
    BTW, the lipsync itself is not ready yet.
    https://vimeo.com/207216689
    Thanks in advance.
    Ground control to Major Tom
    hm, some Bias Map related bug maybe?
    if you're using Bias maps that is.
    hard to say, if no one solves it, share parts of the scene/hair.
    but FiberFX in general is buggy...
    seems to be related to the mesh deforming.
    try decreasing / increasing the SubD level in Layout, could help.
    Los Angeles
    7,125
    It's been a while but I've seen that sort of thing happen when FiberFX is applied or activated at a frame/position that's different from the frame/position where it was setup. I think this causes an internal offset with FiberFX.
    I also remember seeing stuff like that when artists have scaled and/or repositioned the character before applying the MDD, and I'd have tell them not to do that. Or when the MDD was baked from geometry that didn't start with the same exact t-pose that was used in the FiberFX setup.
    Something like that anyways. (Sorry, that was several years ago so I might have some details wrong.)
    Los Angeles
    7,125
    Regarding Sub-D level, you shouldn't change that after you've set up FiberFX. The FiberFX settings will completely change if you change the geometry's density. Ideally, you should apply FiberFX up at the Sub-D level you intend to use at render time.
    Usually, I'll apply FiberFX to a separate 'scalp' or head object that has a fixed polygon level. This way, I can change the Sub-D level for the main character mesh during animation without worrying about this. Also, I like to leave FiberFX disabled when I'm animating...it's really not necessary to have it on for animation and it will probably drag down the system. Just turn it on during lighting and before rendering.
    Jun 2004
    Sao Paulo Brazil
    2,434
    Guys, it is very difficult to find the problem.
    Erik, I didnīt use BIAS map so it is not that.
    Greenlaw, I think I did everything right. I already did other characters the same way and I never had problems.
    It seams the problem is when I edit guides. After that the problem starts.
    I will try again, this time not editing guides. May I can create something decent that way.
    Thank you for you feecback, guys. Really appreciated!
    Los Angeles
    7,125
    Just to be sure, are you using Edit Guides at frame zero or whichever frame you're using as the setup frame?
    I think when you enable edit guide, it's kinda like resetting your bones in the rig, so if anything is out of place from its original position, the binding will be off.
    Hope you get this sorted out...let us know when you do and what you did.
    Jun 2004
    Sao Paulo Brazil
    2,434
    Quote Originally Posted by Greenlaw View Post
    Yes, I am using Editing Guides at frame zero, no doubt.
    I didnīt know yet but maybe the problem is that I have created the morph targets in a position in modeler and then I changed the object position and it is generating those errors.
    I will try what I said before and letīs see what happen...
    Really is a problem with some FFx parameters like Splay, Stray...Use Style and check deactivating parameters.
    You can see it in shaded mode before render in a preview animation.
    Jun 2004
    Sao Paulo Brazil
    2,434
    Quote Originally Posted by dmind View Post
    It is not this. I tried.
    Jun 2004
    Sao Paulo Brazil
    2,434
    I think I tried everything I could. Failed! It is so frustrating...
    Jan 2011
    near a beach
    35
    Subdivision order? Maybe a silly question, sorry if it is.
    share parts of the scene, easier to help.
    creacon
    Nov 2005
    Belgium
    1,299
    Did you bake your deformations to an mdd?
    If not, try that, apply the mdd and see what happens.
    nice work btw.
    creacon
    Jun 2004
    Sao Paulo Brazil
    2,434
    - - - Updated - - -
    Quote Originally Posted by CGI_Artist View Post
    It would be great if that was the problem, but it isnīt...
    - - - Updated - - -
    Quote Originally Posted by creacon View Post
    nice work btw.
    creacon
    I will try it, thanks.
    - - - Updated - - -
    There it is.
    Let me know if you get the problem, please.
    Attached Files Attached Files
    hm, extract operation failed, any chance of a .zip ?
