Thread: Compositing Buffer Export SLOOOOOW!
    registered pixel pusher
    Apr 2004
    los angeles
    30
    I have a 4K render of a car with radiosity/PRMB. The render itself takes 16min per frame. When i enable CompositingBufferExport, the render never finishes... I stopped the render after the "time remaining" passed 24 hours and climbing. Why is this so broken? I can put up with broken Depth passes by using the old fog trick, but i need these additional passes and this problem is a game-changer for production use in the future. V-Ray figured this out long ago, why is it so broken in LW! Please help!
    Registered User ianr's Avatar
    Oct 2006
    Chiltern Riviera
    1,379
    Quote Originally Posted by rustyippolito View Post
    If you got a favor out there, see if you can get time on Fusion Pro.
    Theres even a Multi EXR script to take in the passes spat out from LW
    in Auto mode,and that's Free!
    https://www.youtube.com/watch?v=FFiB9TdynMc
    https://forum.blackmagicdesign.com/v...=39964
    Maybe this can be a new pipe for you?
    Feb 2005
    Barcelona
    310
    I think the problemn is not separating the layers in comp but getting them to render as quick as if Compositing Buffer Export was unable. I deff has to do with CBExport and GI... tested here
    Oct 2006
    Chiltern Riviera
    1,379
    Yes, I know its not about Separating Layers in Comp
    Its about a work-round asking Fusion's Final render to put it
    together ,which BTW is not slow/.
    That's what I am suggesting above. zzzsh!
