Results 1 to 1 of 1
Thread: weightmap problems
    Apr 2008
    Netherlands
    1
    weightmap problems
    I just encountered a problem with applying weightmaps. I modelled a character and applied weightmaps, they appeared in the weight shade mode in Modeller , as usual, with a dissolved edge to the other polygons outside the weighted area. However now, when I reloaded the model deleted the old weight map and applied a new weight map, only the chosen polygons are showing red with a sharp border. The diffused border has dissapeared. When I create a new object in the same window next to my model weight mapping works fine. What could go wrong? Thanks for any clue.
Name:	weightmap problem.jpg
