Thread: Turn off Rig Control Skeleton
    Nov 2016
    Seattle
    16
    I imported an .fbx file. Although I turned off the bone x-ray, how do I make this rig control thing invisible? I don't want anything visible in the workspace except the model itself.
Name:	screenshot - rig.jpg
    Near Beaverton, OR
    1,273
    If the Bone X-ray option isn't doing it, you'll probably have to go into one of the Scene editors & manually turn off visibility for each bone of the fbx hierarchy..
    Nov 2016
    Seattle
    16
    Any tips on how to use this command? Is there a menu shortcut?
    ItemVisibility nvisibility
    Set the visibility of the selected item. The argument can be any of the values returned by the Interface Info global's itemVis function.
    Seems like a whole lotta effort for something that would probably be a toggle switch -- in this case the bone x-ray is the toggle switch. Not sure why it doesn't work.
    Jan 2005
    Colorado Springs
    1,782
    You should be able to get into Scene Editor, select all the bones in the hierarchy by selecting the first one, holding down SHIFT and clicking on the last one to select them all, then clear the visibility column for them, which is the second column on the left labeled with an "eye" at the top.
    mTp
