Thread: Return number of servers on a channel
    Is there a way to return the number of servers applied to the envelope of a channel?
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    Here's the simplest way I can think of. This script looks at the items in the user selection, checks their "X.Position" channel, and prints out any plugins they are using, if any. It also prints the number of servers.
    Code:
    import lwsdk
    # Get ItemID selection (for script-based functions)
    UserSelection = lwsdk.LWInterfaceInfo().selected_items()
    for x in range(0, len(UserSelection)):
    	cGrp = lwsdk.LWItemInfo().chanGroup(UserSelection[x])
    	chan = lwsdk.LWChannelInfo().nextChannel(cGrp, None)
    	while chan!= None:
    		chanName = lwsdk.LWChannelInfo().channelName(chan)
    		# Insert any channel functions here as desired.
    		if chanName == "Position.X":
    			print "Position X Found!"
    			ServerCount = 1
    			while ServerCount != None:
    				Server = lwsdk.LWChannelInfo().server(chan, lwsdk.LWCHANNEL_HCLASS, ServerCount)
    				print Server
    				if Server != None:
    					ServerCount += 1
    				else:
    					NumberOfServers = ServerCount - 1
    					ServerCount = None
    		chan = lwsdk.LWChannelInfo().nextChannel(cGrp, chan)
    	print NumberOfServers
    Now if you want to check whether or not a channel is controlled via an expression... currently I don't know if its possible as I see no functions that can check for their existence.
    Thanks Ryan. I'm already doing something similar. Was hoping there was a direct way to query the number of servers without having to iterate and check.
    www.ernestpchan.com
    Quote Originally Posted by ernpchan View Post
    If you ever find a way to find whether or not a channel is driven by an expression, let me know. Sometimes I need rigging scripts that can pick apart which items are constrained and which are not, and this kind of blocks me from making things fully automatic/error free for the user.
    Quote Originally Posted by Ryan Roye View Post
    Feature request it. I couldn't find anything that let you check that. Just applying and deleting expressions in the lscript dox.
    www.ernestpchan.com
    6,470
    Did anyone ever file this as a feature request?
    There's a bunch of cases like this in LW Python SDK. PRIS (or whatever) ought to provide proper "Pythonic" iterators/generators for processing such entity/attribute lists/hierarchies.
