Results 1 to 9 of 9
Thread: Silhouette edges?
    Axes grinder- Dongle #99
    Seattle
    14,726
    Question Silhouette edges?
    In this image:
    the eyeholes aren't receiving Silhoutte Edges, although other smaller features are.
    Why might that be? The eyeholes are definitely silhouette.
    Praise to Buddha! #resist
    14,672
    works here..
    try do a simple setup first and test on that to make sure your system seem to work ok, then you may need to check your scene what may interfere with it all and track it down by removing stuff till the bones only is left.
    Feb 2006
    england
    1,179
    if it is a subd mesh try freezing, it could be that the physical subd edge is behind the hole so not visible to the camera
    Intel i7 5960X Extreme, Asus Rampage V extreme, 3x 4gb NVIDIA Geforce GTX970, 32GB DDR4 2666 corsair dominator
    14,672
    I could think of another reason, my sample was a complete water tight mesh, meaning it had thickness ..if the smiley sun with eyesocket is just a cut out on anotherwise thin object, it may not be able to work..I noticed my siloutte edges vanished when it tried remodeled it to a thin hollow object.
    So just try run thickener on it..it may help.
    14,672
    May not b necessary to thicken the object, if you check unshared edges..together with silloutte..it may work too.
    try sharp creases as well
    also check smoothness settings on the surface panel, the amount of degreeness affects the outline inkingness
    14,672
    Quote Originally Posted by bazsa73 View Post
    That shouldnīt be needed, it related to smoothing ..but isnīt needed really, unshared edges if the object is thin, if you thicken the object all you should need is silloutte edges, I doubt that will do anything for the edges around the socket.
    Seattle
    14,726
    Good suggestion. I'll let you know.
    UNSHARED EDGES did the trick, although of course it'd be nice to know why one edge works and others don't.
    rusty, I was too chicken to freeze the mesh: I'm a coward! --Maybe later.
    14,672
    As I donīt know, did you model the shape without thickness? in such case shared edges is needed, if you thicken it however.. then I donīt think unshared edges is necessary, but itīs kind of hard to tell from an image only.
    Donīt think freezing is needed, sillouette outline should follow whatever subpatch there is without the need to freeze it.
