Results 1 to 1 of 1
Thread: DP Edge shading issues
    Feb 2014
    Sweden
    89
    Hello good folks!
    I am attempting to use the DP Edge node to fake a high-poly look to my low-poly models. Provided images to show the shading issues I am having.
    With edge node:
    http://image.prntscr.com/image/0a793...fd249c766e.png
    Without:
    http://image.prntscr.com/image/5869b...519ea39bc0.png
    For some reason it is ignoring the middle pieces and I have no idea why.
    Anyone who could help shed some light on this?
    Thanks a ton!
    And oh, whilst I am creating a thread anyways, is the result I am getting from the Edge node, once I get it working, is it bake-able to a normal map so I can use it elsewhere such as in a game engine?
    Edit:
    Okay, so it works if I move everything into the same layer... or if I create a new material for each piece I would assume.
    Well, sweet! Now only the question if it is bakeable somehow remains. Do keep in mind I am absolutely clueless about Lightwave and I am only evaluating adding it into my toolset from time to time, the DP Edge node is almost pushing me over the edge to finally do it!
    http://image.prntscr.com/image/0b81f...d49a153c90.png
    Edit3:
    Getting closer... But calling it a night now.
    http://image.prntscr.com/image/a5ccf...144fa61fa2.png
    Edit4:
    Yippie! Just had to turn off the light. Not the most streamlined workflow or process overall but I am fine with that! Can't wait to play with it more.
    http://image.prntscr.com/image/62913...4a30e3e99e.png
