Results 1 to 2 of 2
Thread: Goz not working
    Goz not working
    I have the latest version of Lightwave 2015.3 and ZBrush 4R7 (Windows 10 64)
    I click the "I/O GOZ" and nothing happens whether ZBrush is open or closed.
    The Lightwave files for GOZ are in the correct directory - C:\Users\Public\Pixologic\GoZApps
    ZBrush has the path to Modeler and Layout. I did a "force reinstall and "update all paths."
    I'm not sure what to try - is there still a problem with GOZ or something I'm doing wrong.
    Jan 2012
    Italy
    210
    It works fine here, same config, only problem I have is switching from lw to zb and reverse causing synch problems with uvs and object surfaces and parts, but I don't know if it suppose to work like that.
    What I do is export in fbx and use the fbx plugin from zbrush, so I have a better control of what the sw is doing.
