Thread: No Settings Panel for Kinect One - Please Help
    Cultural Engineer Liber777's Avatar
    The Most Chosen City on Earth
    618
    I can't get to the Kinect Settings Panel. When I run the device manager, I can see and activate the Kinect One to turn it on and can even rename it from Default to Kinect_A, for example. I can also see all the track values updating in real time.
    The Settings column for the Kinect One shows '(none)' however, instead of 'open...'.
    Can anyone help me?
    Thank you!
    NevronMotion 1.1 / Kinect Runtime 2.0.1409
    LightWave 2015.3
    Kinect One
    Windows 10 Pro / Surface Pro 3
    << Nothing is true, everything is permitted >>
    DaVinci Resolve, Fusion, Generation, LightWave, ChronoSculpt, NevronMotion, REDcine-X Pro,
    Nuendo, messiahStudio Pro 5, VT[4] v4.6, SpeedEDIT 2...
    USA
    33
    Hi, The exact same problem here.
    USA
    33
    Hi Folks,
    Right then, my bad. Totally all right here from Greenlaw. http://forums.newtek.com/showthread....LightWave-2015
    I'm running it on a mac using Bootcamp. Along with others, Thank You Greenlaw. Dude, you nailed it. B e a u t i f u l Post.
    618
    Thanks for that link, Keith. Helped a lot!
