Thread: fiberglass-strands to solid object question
    Newbie Member Bonedaddio's Avatar
    Wrightsville, PA
    36
    Unhappy fiberglass-strands to solid object question
    Ok, I'm not an expert, not a noob.
    I hate "drawing a blank", but I can't seem to figure out the best way to approach this project. I will eventually need to animate strands of fiberglass going into a mold and being extruded, but for right now I really need some pointers on the best way to create a model that looks something like the attached sample (in less than 2 years). I know I can manually create/model the strands, but I think that might get a little tedious and also be tough to animate....
    I've already got an extrusion, at the top.
    Any help would be a greatly appreciated....
    (sig too long)
    PC1: Q6700, Radeon 4850, 2 gb, sata drives, etc.
    PC2: Core i7 920, Radeon 5750, 9 gb, sata drives, w7 64bit
    MAC: MacPro Quad Xeon 3ghz, Radeon X1900 XT, 3 gb, blu-ray burner
    suspended in Gaffa noiseboy's Avatar
    London,UK
    438
    I would think that Sasquatch would be ideal for generating the fibre strands. You should be able to pull them though a Die as well, I'm not sure that you would be abe to do it with the lite version though.
    Sorry don't know the answer.
    I was looking at this Pin Array tut last night. It's probably not the answer but might spark some ideas.
    http://www.eyelandarts.com/tut/pinarrays.html
