Thread: How to add mocap to character?
    Question How to add mocap to character?
    Hi Guys,
    I'm trying to add mocap moves to the object.
    I think that lack little, if anyone knows thanks.
    There is my scene..
    Mocap-to-characj.rar
    tks,
    Eduardo
    Registered User OjN's Avatar
    Mar 2014
    Grand Rapids, Mi
    103
    I believe your best option is to create a new rig (import bones from Dstorm and put in order) and copy the motion of the original mocap rig without scaling or changing anything. I invite you to use the free retargeting tool of Ryan.
    https://www.lightwave3d.com/assets/p...ry/load-bones/
    http://www.liberty3d.com/citizens/ry...-free-plugins/
    More info: http://forums.newtek.com/showthread....ht=retargeting
    hmm,
    Very nice this plugin and this idea.
    I make the skeleton in Genoma...with the Ryan retargeting may be will be easy...
    I need a scene with 15 people wallking in the street...,I hope works...
    tks,
    Eds
    Quote Originally Posted by edu190 View Post
    hmm,
    There are currently 3 general options when it comes to Lightwave and retargeting, each with their pros/cons:
    1) IKBooster + scripting (lscript commander, lscript, or Python)
    Pro: Minimal scene overhead, can be made to work on any rig. No mesh baking required in most cases, even with 15 low-to-mid resolution characters.
    Con: Setup for a single template can be time consuming, higher learning curve. Part time IK only without use of plugins.
    2) Nevron retargeting
    Pro: Easy setup and user-friendly layer-based editing. Lowest learning curve of the 3 options.
    Con: You are restricted to provided rig. Massive hit to scene overhead, you will need to bake your animations into MDD format even with 3-4 figures.
    3) Rhiggit 2
    Pro: More efficient than Nevron rigs, modular system will "retarget" your custom rig properly so long as your rig is made with Rhiggit elements.
    Con: Heavy hit to scene overhead (using the most basic rig), you will still need to bake animations to MDD format for workable playback with 15 figures.
    The reason I don't mention my retargeter plugin is that it isn't finished yet and I have no plans to support or update it until it is... so until that time, the above 3 options are what you have at your disposal, take some time to evaluate what your production needs are and choose carefully. I do expect these options to expand and/or change by next year... if not sooner.
    Thanks Ryan,
    Still complicated. This your plugin still is the easiest for me.
    I have mocaps, some 3d objects with a good texturing, I need to mix this 2...
    I installed your plugin, not sure.
    I try to SET mocap bones and objectīs bones from genoma presets and didnīt work.
    I donīt know if is my fault.
    tks,
    Eds
    Now legs are deforming
    Hi ,
    Using free retageting tool from Ryan.
    Iīm stuck in strange legs.....kkkk
    I add 2 bones trying to fix, but didnīt work... any idea?
    BVH-to-Person-strange-legs.rarBVH-to-Person-strange-legs.rar
    tks,
    Eduardo
