Thread: Exact point reduction tool?
    14,672
    Hi folks..
    Isnīt there an exact point reduction tool, for reducing an object to exact point count?, with that I am thinking of getting exact match between different objects for morphs.
    are you thinking of using bkg to morph?
    if so you also need the 32bit plugin > 3DD MeshRekniter
    https://www.youtube.com/watch?v=7_ISeyMKc_A
    other than that, what about doing it manually?
    14,672
    not necessery, but it will pass through that route too, firstly though just a basic layout morph to morph target...not sure if there was plugin to handle different point counts though using morph target?
    yeah I know...I actually downloaded that plugin before I wrote this thread.
    manually..meh...sounds tedious just with a medium dense object to get another object having the same point count.
    ah, yeah, could take time if not low poly
    sorry, can't think of a fast solution for this one...
    i guess a semi-ok method is to select random points automatically
    then use "Close Holes"
