Results 1 to 10 of 10
Thread: cloth help please
    las vegas
    666
    cloth help please
    can anyone tell me how to smooth out these crinkly areas? i've included my settings for the cloth object.Click image for larger version.
ID:	128237Click image for larger version.
ID:	128238Click image for larger version.
    do you have smoothing on for the surface? and last for deformation.
    las vegas
    666
    yep
    freeze it and bring it into Modeler
    then Shift+D > Metaform
    then smoothing... does it help ?
    las vegas
    666
    that pretty much worked, thanks
    well, not really.
    it smoothed it out a little, but still lots of crinkle.
    Sep 2003
    France
    496
    It's better to divide into "Modeler" until after the deformation.
    Do the "Faceted", then increases the level of "SubPatch" and relaunch the simulation.
    Here the angles of deformation are too extreme to make economy of polygons. However you can locate and "Faceted" on those parts which are well deformed. You connected all by retopology to avoid the "N-gons".
    Sep 2003
    France
    496
    You can also invest in "LW Brush". With you'll create your deformation directly in "Modeler" :
    https://www.lightwave3d.com/assets/p...ntry/LW-brush/
    If the look you are going for is that of an Austrian curtain, you'd have all kind of odd wrinkles show up anyway. At least where the lift lines are.
    Sydney
    8,273
    You need to subdivide your curtain in Modeler for the cloth to work well, and turn on Subpatches for it. Then in Layout set Subdivision to last in the Properties panel>Geometry tab. The subpatch will then smooth AFTER the curtain has been crinkled by the dynamics, resulting in a nice smooth rippled effect.
    las vegas
    666
    lightwave brush looks awesome, thanks, i'll pick that up. in the mean time i think i solved my problem using some of the other elements that will need to be in the final image.
