Results 1 to 8 of 8
Thread: why are the lights flickering...? dof?
    Sep 2010
    florida
    143
    is it that i am using depth of field? seems like when i turn that on i get this. has anyone figured out how i can fix it?
    England
    5,749
    Any pics or video examples? It's hard to tell without some samples.
    It could be Global Illumination? Or interpolated GI... or something else entirely. Not sure if it's becuase of DoF...
    Desk Work:
    Desk Home:
    Sep 2010
    florida
    143
    duah, global illumination! that's it. i sure wish i could use that function
    England
    5,749
    Quote Originally Posted by stylus10 View Post
    You can use it, but you need to be able to know what settings will work for your scene.
    Can you post any examples of what the issues are?
    Desk Work:
    Desk Home:
    Aug 2006
    Hendersonville, NC
    6,962
    These are the settings I use.
    shrox www.shrox.com
    Heavy Metal Landing
    gold plated 3D Chrusion's Avatar
    Chatannooga, TN
    1,080
    Enable GI Cache, Enable Animation, set Preprocess = Automatic, set Frame Step = 1, set path to "radiosity" folder in your content dir and desired filename.cac (if no radiosity folder, create one). Temporarily set RPE = 1, SBR = 1. Set Ray Trace options off, except shadows. Bake Radiosity Scene. Return RT and GI to original settings. Set GI Preprocess = Locked. Save scene and render away without GI flicker.
    You'll get a single cache file in your radiosity folder instead of multiple files every frame step. With frame step = 1 you'll also benefit from reduced calcs time since the samples from the previous frame are used and only new samples added as new geometry comes into view (the old LW 11.0 cache method minus the ability to do frame step > 1).
    Setting RPE and SBR = 1 signifiactly reduces calc time as only the locations of the samples are recorded/needed for caching, so no need to throw hundreds of rays from that one location out into the scene, slowing down baking. Turning RT options of also speeds baking and are not part of the sample locating preprocess stage.
    Dean A. Scott, mfa
    Senior 3D Animator and Graphic Design Illustrator, @ Astec, Inc.
    Owner / Lead Artist @ chrusion | FX
    Aug 2006
    Hendersonville, NC
    6,962
    Quote Originally Posted by Chrusion View Post
    Even better!
    shrox www.shrox.com
    Heavy Metal Landing
    Jul 2014
    Baku
    501
    Will this be helpful with backdrop rdiosity? or what Chrusion said is for Montecarlo? I have the same issue with flickering.
