Results 1 to 10 of 10
Thread: how to use MTL files?
    Aug 2011
    malaysia
    34
    hi,
    i got a free obj mesh from the net and it came with a mtl file. when i load the obj in modeler i can't see any textures on the model.
    how do i get the mtl file applied to the model? sorry if this is a silly question.
    tnx.
    Just make sure the textures, .obj and .mtl are in the same folder and it will find everything. Then once loaded into modeler save as .lwo.
    -M
    I was thinking of the immortal words of Socrates - "I Drank What??"
    Aug 2011
    malaysia
    34
    hi MSherak,
    yes, everything is in one folder on my desktop. i opened it and saved as lwo but still the textures does not show. am i doing something wrong?
    Aug 2006
    S
    3,511
    ... textures in the same folder too. With the .lwo you'll have to load them manually.
    Aug 2011
    malaysia
    34
    meshpig,
    yes, everything in same folder...jpeg, mtl and obj files.
    if i load the textures manually, what does the mtl file do?
    Aug 2006
    S
    3,511
    it's just the property file, so to speak for the materials. Hence "mtl"... like the "fbm" folder for FBX.
    Aug 2011
    malaysia
    34
    meshpig,
    ok. tnx much.
    Quote Originally Posted by leoitch View Post
    meshpig,
    The mtl file makes sure that the surface names come over and assigned to the polygons. You will still have to load the textures and assign manually them under the T button since OBJ importing does not do that for you automatically. So just load the textures, go under the T button and assign the UV and the texture to the surface.
    -M
    Murcia, Spain
    2,879
    If your having problems still. Mike Green had a good script to import .MTL files as well
    Dell XPS 15
    Intel i7 7700HQ 2.8GHz
    Windows 10 64Bit
    NVidia GeForce GTX 1050 Ti
    1TB SDD
    32Gb Ram
    LightWave 2018.4
    Very nice Laptop
    you can simply open the MTL file in a code or text editor and if the object is not too complex, check if the texture paths and names are correct and actually correspond to what you have on disk. if the names are different, you can fix them in the text editor and resave the file. also make sure that the MTL file has exactly the same file name (but of course with MTL extension) as the OBJ file - usually programs save it as such. if the MTL file has a different name than specified in the OBJ it will be simply ignored by LW when loading the OBJ.
    also you can open the OBJ with a text editor and make sure that you find in one of the first lines the name of the MTL file which need to be loaded. search for the line beginning with
    Code:
     mtllib name_of_the_mtl_file.mtl
    where 'name_of_the_mtl_file' is obviously the name of this file.
    hope this helps, let us know ;-)
    cheers
    markus
    3dworks visual computing
    demo reel on vimeo
    instagram
