Results 1 to 2 of 2
Thread: HELP! LW and fiber fx strange issue. IS this a bug??
    Aug 2006
    UK
    188
    Unhappy HELP! LW and fiber fx strange issue. IS this a bug??
    I just come across something that's not happened before. I have a head loaded in modeler. I added some fiber fx guides for eyelashes and copied them from layer 2 back onto layer one (The head) I then sent it over to layout. Without activating the fiber fx I hit render and you can see the head and the fiber guides. Now I activate fiber fx and suddenly the head doesn't render anymore and just the guides are rendered. IF I now de-activate fiber fx and render again, the head still does not render. Just the fiber fx guides render. Whats going on???
    That really sounds like a bug - you should at least be able to get the head to render again. Have you tried it with a different object (maybe just a ball with an eyelash on it?) See if you can isolate the problem to a particular scene, object or feature or if it keeps happening regardless. If you can make it happen over and over, package the scene and send it to support - let them have a look.
