Results 1 to 11 of 11
Thread: LW Modeller 2015 crash when try to use cut command (+U)
    when I try to use this command in modeller 2015 always crash.
    Report Sent
    Attached Files Attached Files
    Axes grinder- Dongle #99
    Seattle
    14,726
    Huh, that's a bad name, considering "Cut & Paste" is common vernacular-- since it REQUIRES Edges to be selected, "Edge Cut" would be a better name. Anyway....
    In 11.6.3 Win I get a warning if I don't have EDGES selected. Do you have Edges selected before hitting +U?
    (I'm also ambivalent about the switch to Point Mode once you use this tool....maybe it makes sense, sometimes such things are quite convenient....)
    Praise to Buddha! #resist
    Yes the edge was selected
    Seattle
    14,726
    Welp, looks like you found yourself a bug! Congratulations, now please submit a report.
    I already did
    I can't work in LW Modeler 2015, because I use cut tool many times
    Professional amateur Amurrell's Avatar
    Dec 2005
    Lincoln, NE
    1,350
    Yeah I reported this also a while back and they said it didn't happen on the internal build. If you got them to see something different that would be great. I sent a video as well, but apparently they don't watch them by the further questioning I got. Cut will work with polygons selected. Cut does work with edges selected but adding or deleting cuts with the tool open and edges selected crashes modeler. Polygons, as said before works.
    --Andrew
    Bono Animo Esto
    Intel Core i5 3570k
    nVidia GTX 970
    8GB DDR3 1333MHz
    Windows 10 Pro 64bit
    This is the answer of LightWave Customer Support .
    This has been fixed in an upcoming patch
    Thank you for your report.
    LightWave 3D Group Support
    Thanks LightWave Customer Support
    it works in LW 2015.1
    Thanks again LightWave Customer Support
    Seattle
    14,726
    wait, what?? 2015.1 is released? I just did a quick whiparound on the forum and didn't see any announcement.
    I don't think there is a official announcement thread. I made one about it 3 hours ago though: http://forums.newtek.com/showthread....LW-2015-is-out
    -Joshua Jorgensen
    Seattle
    14,726
    Well, they haven't mentioned it on their FB page, so I'll not whinge about it TOO loudly...
    Also, good job on getting that out b4 the break, LW3dG!!
    Now go take a nice holiday!
