Results 1 to 10 of 10
Thread: Spline Control path into Modeller
    London
    2,306
    I have an object using Spline Control. SC is made up of 5 nodes and I really need the path in Modeller. I'm currently having to bake the motion of an object using SC but I'd much rather just have a spline in Modeller made up of 5 points in the same positions as in Layout. Any quick "Send Spline to Modeller" script recommended?
    You should be able to use this. https://www.lightwave3d.com/assets/p...data-importer/
    You'll have to manually make the text file with your vectors but since you only have 5 that shouldn't be too bad. I could look into making a companion script to get selected nulls and the make the list of vectors.
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    London
    2,306
    Thanks ernpchan, I think I'm just going to have to get used to generating these things in Modeller first, workable but really annoying without any camera reference.
    I'll still make the script to generate the vector list from Layout. At the very least it's an interesting scripting puzzle for me.
    Maybe I could then figure out a way to make the connection between Layout and Modeler more seamless.
    www.ernestpchan.com
    London
    2,306
    Good luck! I've tried a couple of those Scene to Modeler scripts but don't work with nulls, just objects.
    Quote Originally Posted by raw-m View Post
    I was able to make this curve from the DinoShark_Animation scene that comes with the 11.6 content. Unclear to me if that geo is useful or not though.
    Attached Files Attached Files
    www.ernestpchan.com
    Axes grinder- Dongle #99
    Seattle
    14,726
    (here I go again) On that notional whiteboard in the notional devs office, it'd be nice if one of the checklist items was "Two-way data exchange".
    That is: Spline Control is GREAT, don't get me wrong, but it would be nice if it were anticipated that everything we can send to Layout we should be able to send to Modeler.
    If one is going to plant the flag on the separation of the two apps, AKA "anti-unification", one should also make that separation as functional as possible. That means a two-way street for ALL data.
    (Fortunately, this is the kind of thing that can most likely be solved with a script, a neglected strategy in my opinion.)
    Praise to Buddha! #resist
    skeptic lertola2's Avatar
    Dec 2008
    New York City
    1,102
    There is an Export_Spline command in Layout. Is that what you want?
    London
    2,306
    Blimey! Thanks lertola2. How long has that been there?!
    Seattle
    14,726
    cool, but app error...
    Quote Originally Posted by lertola2 View Post
    DAMN! Mine was unassigned!!! Sheesh. Where is it usually in the UI???
    Good catch lertola2!
    OH WAIT:
    I get a "Cannot load external plugin" error..... will investigate.
