Results 1 to 11 of 11
Thread: Plug and Play Audio Control Surface options?
    Feb 2011
    Mililani, HI
    105
    Is there any audio control surface with faders (besides the iOS app) that is plugin and play without added 3rd party software?
    I'd like to be able to physically mute, fade audio, adjust audio and have it reflect in the TriCaster Audio mixer.
    I am aware of MidiDoll. Justlooking for a simple physical mixer audio control surface.
    Thanks in advance.
    4,212
    Here check this out, it plugs in and works perfectly with the TriCaster:
    Jef Kethley
    PIZAZZ
    www.pizazz.com
    Using:
    Panasonic UB300 4k cams
    4,212
    Just messing with you,
    besides MidiDoll and a Behringer midi controller there is the Avid control surface. But it only works with the TriCaster 8000 not the 860/460 models.
    Jef Kethley
    PIZAZZ
    www.pizazz.com
    Using:
    Registered User Paris MkVI's Avatar
    Sep 2014
    Virginia
    106
    Jef, our company spec'd that SI console for our system, but never told us it interfaced directly with the Tricaster for control. Am I understanding correctly that it will work as a control surface, including effects? If so, what is the process to integrate it?
    Tricaster 460
    HD-SDI over coax
    JVC 890 x 2
    Panasonic 370 x 1
    4,212
    You can adapt the SPDIF digital output and bring in the output of the SI console into the AES/EBU audio input on the TriCaster. That digital output can be practically any output of the board via the soft patch.
    You would not have control of the actual audio software mixer of the TriCaster. You would just leave up whichever inputs you are feeding the output of the Soundcraft into. Apply Audio Follow Video settings to that input in case you need to do DDR rolls with only DDR audio.
    Sorry if my humor didn't come through on the post above. The OP and I have talked before about this so I was just twisting his arm some.
    Jef Kethley
    PIZAZZ
    www.pizazz.com
    Using:
    Sep 2014
    Virginia
    106
    Ah, gotcha - thanks Jef!
    Tricaster 460
    HD-SDI over coax
    JVC 890 x 2
    Panasonic 370 x 1
    Feb 2011
    Bowie, MD
    45
    Quote Originally Posted by PIZAZZ View Post
    ...besides MidiDoll and a Behringer midi controller there is the Avid control surface. But it only works with the TriCaster 8000 not the 860/460 models.
    Can you clarify this statement? The manual makes no mention of the Avid Artist Mix only working with the 8000, and I was looking forward to being able to add an Artist Mix to a 460 in the future.
    19,080
    To paraphrase Ronald L. Ziegler (and who doesn't like to do that?), 'The former statement is inoperative'.
    Support for the Artist Mix was extended to the full line of Pro TriCasters some time ago ... I'd have to look back to see when. So for once, at least, the manual is correct.
    4,212
    Well then I will revise my original statement... I still would buy a Soundcraft or PreSonus digital board versus spending that much on an Avid Mix controller though
    And Steve, there is always a first time. Congrats!
    Jef Kethley
    PIZAZZ
    www.pizazz.com
    Using:
    19,080
    Even a stopped clock is right twice a day.
    Feb 2011
    Mililani, HI
    105
    Thanks Jef, the PreSonus works perfectly fine! I think we'll stick with that.
