Thread: Frame buffers 8000.
    Oct 2014
    Pittsburgh
    1
    Frame buffers 8000.
    Thoughts on how to use/make frame buffers on 8000.
    I assume you are talking about Animated Frame Buffers? You can use anything you want. Lightwave, After Effects, Fusion, Motion, SpeedEdit. Just just need an image sequence to import into ASC.
    Limit is 600 frames per animation, but recommend try to try to keep to around 300 if possible so that you don't end up running out of switcher memory.
    Key Accounts Sales Engineer
    4,214
    Quote Originally Posted by vbob View Post
    Looping backgrounds for use in virtual sets.
    Looping Station / Event IDs for watermarking content.
    Remotely updated graphics information from a 3rd Party Vendor software.
    Looping Logo Spin either of our client to place in any empty monitor on the multiviewer so the client sees that over our shoulder all the time on the 60" LCD screen.
    My favorite, after some conversion of course, placed in a empty slot...
    Jef Kethley
    PIZAZZ
    www.pizazz.com
    Using:
    Panasonic UB300 4k cams
    NewTek Engineering ACross's Avatar
    San Antonio
    795
    It is often overlooked that the animated buffers perform full motion interpolation of frames (think how much processing that is in addition to everything else the product does, when using 10+ buffers, virtual sets, 3D effects, etc...!) ... almost any other product out there at best duplicates frames (and most only play at exactly 100%). This means that you can design buffers that have a relatively few number of frames that may still have entirely smooth motion.
    Oct 2012
    Munich, Germany
    80
    It would be nice to have to option to not having to used full size pcitures all the time.
    When animating a small logo only the memory is wasted with a huge amount of transparent section pixels.
    Or is there any picture compression features built in that solves this problem ?
    best regards,
    Walter
    TC8000 / TW850
    Cables: Belden 1694/Canara Connectors
    Cams: Sony PWM-EX3, Sony HDR-CX430/BMD HDMI2SDI
    San Antonio
    795
    Walter,
    Internally the code will not use memory for areas of the image that are not used.
    Andrew
