Results 1 to 1 of 1
Thread: TriCaster SD - Captrured Clips and Final Cut Pro
    Moderator
    earth
    203
    Problem Description
    Why do the TriCaster captured clips show up in Final Cut Pro at 640x480?
    Solution/Workaround
    Contrary to what you may see in the Final Cut Viewer or Canvas, the TriCaster clips really are captured in full video resolution (720x480 in NTSC). Final Cut Pro does not display the proper resolution, until you tell it the aspect ratio:
    1. Click on the clip in the Browser.
    2. Hit Command - 9.
    3. Check the box that says Anamorphic.
    4. Close the window.
    5. Double click the clip to load it into the viewer.
    NewTek Customer Support
