  1. User Interface
    Provides complete control over live production, streaming, recording, and media publishing operations, with support for synchronized, mirrored operation between multiple TriCaster 8000 systems connected to the same local network.
  2. Recordable Macros
    Make your favorite series of commands automatic. Record any sequence of operations as a macro event, make adjustments as needed with the built-in Macro Editor, then trigger with a single click, keystroke or button press. Talent can also trigger macros by making contact with configurable on-screen hotspots.
  3. Workspace
    Create a view that works for you. Customize the User Interface and Multiview monitors, populating a variety of layouts with your preferred combination of inputs, outputs, scopes, clocks or images.
  4. Live Streaming
    Launch live streaming video of your show to the Web with simultaneous archive, at the touch of a button. TriCaster 8000 includes presets for the most common streaming profiles, in resolutions up to 720p, with support for custom multi-bitrate stream profiles.
  5. Grab
    The unique view from every angle is up for grabs. Snap photos from inputs, buffers and outputs, simultaneouslyone or all cameras, simultaneously; build a collection of HD still images to post to social media sites, or use during the show.
  6. Recording
    Capture video from up to 8 individual sources, simultaneously, with integrated IsoCorder™ multi-track, multi-format recording technology. Files are recorded at native resolution, and compatible with every major non-linear editing application, computer operating system, and media sharing website.
Name:	Media Publishing.png
    A. Media Publishing
    Publish content instantly to popular social media sites like YouTube™, Facebook and Twitter™, upload to FTP sites, or transfer to storage volumes and network locations. Share clips and stills during live production or upload your full-length show within moments after production wraps.
  7. Live Desktop Monitors
    Create a custom workspace layout with your choice of virtual monitors. Full field rate displays also include convenient options for additional customization, including safe areas, VU meters, and alpha channel transparency display.
  8. Cameras
    Connect up to 8 live cameras or video sources, of any connection type or resolution. TriCaster 8000 also supports direct connection and control of Pan-Tilt-Zoom (PTZ) cameras and upstream external video routers; making countless, additional cameras and video sources available from the switcher.
Name:	4RU PTZ Default.png
    B. Pan-Tilt-Zoom (PTZ) Camera Control
    Control up to 8 robotic PTZ cameras directly from the User Interface, including camera orientation, zoom, focus and iris. Position presets with thumbnail preview make it easy to setup shots remotely and change angles on the fly.
  9. Network Sources
    Share computer screens or displays from wireless Apple® AirPlay® devices, like iPad®, iPhone®, or iPod®, connected to the same local network. TriCaster 8000 also accepts video over IP, streaming servers, USB video sources, NewTek 3Play™ and TriCaster systems, as well as a variety of third-party partner solutions as network inputs.
  10. DDRs
    Load and playback video clips, packages and motion graphics. TriCaster 8000 offers native support for almost every file format, with per-clip audio levels, scaling and aspect ratio conversion, allowing you to work with essentially any media asset you're given.
  11. Graphics
    Display images, apply titles or present static graphics. Choose and edit templates in a variety of styles and designs, or import your own graphics for a custom-branded live production.
  12. Look-Ahead Preview Monitor
    Set up and preview your next shot before it goes live, including any titles and overlays to be applied.
  13. Program Monitor
    View the primary video output signal being broadcast, streamed, projected and/or recorded.
  14. Live Virtual Sets
    Up the production value of any presentation with a multi-source virtual set, complete with real-time reflections and specular highlights. TriCaster 8000 includes more than 30 HD virtual sets in a variety of styles and settings, each with multiple angles, customizable pan, zoom and pedestal animations, shot presets, and support for motion tracking and macro hotspots.
ID:	124620Click image for larger version.
    C. Holographic Live Virtual Sets
    Create custom, photorealistic virtual environments from panoramic images snapped with a smartphone, point-and-shoot or DSLR camera, with support for 3D positioning of sources and live virtual camera movements.
  15. M/E Buses
    Mix multi-source compositions or create complex video effects, and configure for output; feed into the main switcher, any DSK or Key layer, or another M/E bus; or designate as an alternative recording mix. TriCaster 8000 features 8 M/E buses, each a complete switcher with independent keying and positioning effects per selected source, 4 Key layers, the powerful TransWarp effects engine, and presets. M/E buses also support 3D video production, real-time motion tracking, macro hotspots, and live virtual sets.
  16. M/E Re-Entry
    Create sophisticated, layered effects for virtually any application. Every switcher channel is available as a source for an M/E bus, including other M/Es, allowing for incredibly deep and complex effects operations.
  17. M/E Effects
    Apply titles, graphics and spectacular effects to M/E compositions. Each M/E bus accommodates a transition effect between the A and B rows in Mix mode, supports a layering effect or virtual set in Effect mode, and includes 4 fully configurable Key layers – each with independent keying, positioning effects, transition controls and support for TransWarp effects.
  18. Live Production Switcher
    Control productions of any scale, in all resolutions up to 1080p. Integrate multiple cameras, video feeds, network sources, stored media, graphics, transitions and effects without any extra hardware or external devices.
  19. Switcher Effects
    Apply titles, graphics and spectacular effects to live video. The switcher supports dynamic TransWarp effects on the primary video layer, and on each of the 4 fully configurable DSKs. Each DSK also includes independent keying, positioning effects and transition controls.
  20. TransWarp Effects
    Supported on every available effects channel, the TransWarp effects engine is simply the most powerful integrated effects system in live production. TriCaster 8000 electrifies live video, DSKs and Key layers with full-color animation store transitions, complete with embedded audio and 3D warping of video. The integrated Animation Store Creator application also allows you to build custom transitions and effects, with eye-catching visuals like real-time cloth dynamics, 3D transformations and motion overlays.
  21. Media
    Load video clips, motion graphics, sounds, titles and stills of virtually any file format for live playback or overlay. Build playlists before or during a show, and save frequently used video and graphics collections as presets.
  22. Buffers
    Access up to 15 additional media sources – instantly – during live production, including video clips, animations, images, titles and graphics. TriCaster 8000 supports 10 animation buffers and 5 still & title buffers, each with independent playback and transition controls, plus presets. View and manage buffer content via the integrated multiviewer, including animation preview and live title editing.
Name:	8000 Mixer.png
D. Multi-Channel Audio Mixer
Deliver pristine sound with adjustable audio for all internal and external resources, plus 4 fully independent stereo output mixes. Enjoy precision control, including robust audio follow video and routing configuration, per-input audio delay timing, and a seven-band equalizer and compressor/limiter on every source and output. Touchscreen and tactile remote control are also in the mix, via the companion iPad audio mixing app and native support for Avid® Artist Mix audio control surfaces.
