Results 1 to 13 of 13
Thread: FiberFX Problem
    Apr 2014
    USA
    28
    FiberFX Problem
    I'm trying to create grass with FiberFX, but when I look in VPR and export it, it doesn't show and is just black. Any ideas on how to fix it?
    14,693
    Quote Originally Posted by ChristopherVFX View Post
    Export to what and why exporting?
    VPR will not showcase fiberfx unless you check the volume only, otherwise you are using the pixel filter which VPR currently donīt support, the pixel filter is faster and renders only with final render.
    Grass on larger areas are not fiberfx strong area, use instanced geometry, like the one in the later lw content scenes, or use sasquatch for grass..it does a much better job at that.
    Apr 2014
    USA
    28
    Thanks, but I can't find Sasquatch. I go to the object's properties and under Deform>Add Displacement there is no Sasquatch or SasLite, or anything.
    Sydney
    8,274
    Sasquatch is a paid for plugin.
    Really, the best way to do grass is instances, FFX just isn't up to the task.
    Often Banned Megalodon2.0's Avatar
    Oct 2012
    Midlothian, VA
    1,029
    Quote Originally Posted by Dodgy View Post
    Yeah, we still use Sasquatch for grass in archviz stuff. Absolutely love it. Of course it is $200, but then when I first bought it I believe it was $499?
    http://www.worley.com/E/Products/sas...sasquatch.html
    Sydney
    8,274
    Yeah, it's great for grass if you're willing to pay for it I was, but this lad might not want to!
    Oct 2012
    Midlothian, VA
    1,029
    I would have to think twice as well - especially since Worley seems to be MIA and no further development on anything, AFAIK. Still a great plugin AND a dependable hair solution. Too bad it doesn't work with anything but the Classic camera.
    14,693
    Sasquatch lite used to be free and shipped with lightwave up till a certain version, canīt recall when they removed that out, maybe when newtek opted for fiberfx instead?
    14,693
    welll...we talked sasquatch here, we have already mentioned ffx isnīt up to the task.
    sasquatch is capable of it indeed.
    http://www.worley.com/E/Products/sas...rendering.html
    http://www.worley.com/Media/animatio...ch/chopper.avi
    Itīs a bit more tricky to animate dynamics with instances, especially on large areas with a chopper affecting only a certain part..while moving all over the grass.
    fiberfx can produce nice gravity motion for dynamics, based on ripple procedurals and referencing a null object while moving, but it only works decent on small grass patches.
    Apr 2014
    USA
    28
    Thanks for all the info. In FiberFX, I checked Volume only, and it still isn't showing. Any ideas?
    Registered User Chernoby's Avatar
    Jul 2014
    St Louis
    157
    I had this same problem. I don't remember how I fixed it but it got to a point where I tried 12 or more things at once out frustration and then when I tested it, it started working. So I have no idea what the actual trick was.
    Adjust the seld shadowing and cast shadowing options in various ways.
    Click on the fiberfx panel, click the "preview" off and back on.
    Peruse the "Display" and Gui settings.
    Toggle the settings of the VPR box in the upper right and toggle the "draft mode" and such on and off.
    I think I added a new camera at one point.
    This might be the one that worked and it sounds the least reasonable. Open the fiberfx panel. Click on anywhere in the panel that doesn't have a button but isn't the Mac or Windows bars above the window. Then click anywhere on the layout screen (not the side or bottom or top panels but the perspective of camera).
    Try rendering out not in non-VPR mode.
    Sorry couldn't provide an accurate answer. I have no idea if these will work. But it finally went away and I haven't seen it since.
    14,693
    I also had some issues with it, I had to save and close the scene, close and reboot lightwave and then it showed up.
    Apr 2014
    USA
    28
    Quote Originally Posted by Chernoby View Post
    Any advice you can give is a big help, even if you don't know specifically what the answer is.
    Thanks again, guys. I've been having kind of a rough time with Lightwave as I've had some difficulty finding really good tutorials on what it is I'm wanting, but I found a few recently. Both that, and you guys on this forum have helped me try thinking outside of my normal processes.
