Results 1 to 1 of 1
Thread: USB to Serial adapters
    Moderator
    earth
    203
    PROBLEM DESCRIPTION
    Regarding the use of USB to Serial adapters and which drivers are supported on TriCaster without triggering the screen to restore software.
    SOLUTION/WORKAROUND
    Following a TriCaster update (the week of 1/27/2014) Engineering has approved Prolific drivers for use with TriCaster.
    Many devices use these types of drivers but not all install the same way. The official driver for the approved hardware implementation can be found here:
    http://www.tripplite.com/shared/soft...R2-7-and-8.zip
    For an exact hardware match you can this link to the device:
    http://www.amazon.com/Tripp-Lite-USA...+lite+usa-19hs
    NewTek Customer Support
