Results 1 to 15 of 16
Thread: Put a bone WITH weight map at every point of a (sparse) object?
    Axes grinder- Dongle #99
    Seattle
    14,726
    Question Put a bone WITH weight map at every point of a (sparse) object?
    #awayFromLW
    How would I put a bone at every point in a sparse object, AND create a weight map for that point/bone combo? (That last part may be gilding the lily.)
    If I can Clone skelegons, I guess I can just use PARTICLE CLONE (Point Clone?) and I'm done, if I don't need w.maps. I'd like that option though, just for maximum control.
    #disclaimer: I rarely use bones/skelegons, so I'm a bit fuzzy on them.
    This is on the heels of watching Cody's "Web Network" tutorial (thank you!) and pondering how to stretch bits of the network around in a controlled fashion. --'Cuz you KNOW some art director will throw a hissy if you can't.
    Praise to Buddha! #resist
    You could try using bones that have a limited fall off. As long as the bone influence doesn't overlap your other parts you should be fine.
    I can't think of an automated native way to do this. You might be able to do it via scripting with pseudo code like the below:
    1. Iterate through polygon islands.
    2. Make skelegon based on center of polygon island.
    3. Make weight map for polygon island.
    4. Assign weight map to skelegon.
    5. Repeat
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    da what? daforum's Avatar
    May 2006
    Bristol, England
    1,666
    Oh yeah I remember this script. It's helpful for creating a faux-lattice.
    www.ernestpchan.com
    Seattle
    14,726
    #rendering
    I'll look at that script in a minute, thanks daforum, but meanwhile:
    Is there a way to get BONES to stick to an object's deformations? Here, the network is getting radically displaced, so the Bones are now far away from their appropriate points. I'd prefer that the diplacement affect both the points and the associated Bones.
    Thanks!
    Seattle
    14,726
    Daforum, as it turns out, that script would be overkill, but still useful. I used PARTICLE CLONE to clone skelegons to all the points --of course, they weren't normal-oriented like this would do, but in this case it doesn't matter.
    Now I'm wrestling with 1) post #5 above and 2) a good looking DOF (which I'm terrible at...).
    Thanks!
    it's a manhole cover ↓ JoePoe's Avatar
    Jun 2006
    LISA
    1,969
    How about Ultimate Clone
    1) made bone with weight map
    2) ran UC ..... used normals.
    3) Merged points.
    base of bones had 100% tips 0% Click image for larger version.
ID:	122098 Works fine (if I understand) Click image for larger version.
    Don't know about the deformation. yet.
    Are you also subdivided?
    ...and where is this tutorial?
    System Specs: A pile of sand, a couple of wires, a real live mouse and a beer.
    Seattle
    14,726
    Joe, I wanted a DIFFERENT w.map with every bone. Each point gets its own w.map. --Most likely overkill, but would give ultimate control.
    ED: https://www.lightwave3d.com/learn/ar...ork-animation/
    Jun 2006
    LISA
    1,969
    A different map entirely with each bone or a different map VALUE with each bone (one map total, then use a gradient to do whatever)?
    The first sounds painful. The second .... not so bad....I've got a couple ideas if that's what you mean.
    edit: hmm, maybe in bone props you need separate maps..... just thinkin'.
    Seattle
    14,726
    Well, my possibly dumb thought was, each point gets it's OWN w.map with only that point being 100%. Of course, that's very VERY likely to be overkill. Very. Even w/no maps, there doesn't seem to be much overlap (but it would still be "nice" to know it's possible).
    The REAL problem currently is that the Displacement map moves the mesh significantly far enough from the bones that there's no visual connection between the bones and the points. Which is pretty much the point of this.
    May 2014
    Greece
    141
    Why don't you use morphs, morphs with displacement or simply bones without displacement ?
    Seattle
    14,726
    Because that's not the effect I'm trying for. It's a riff on this:
    But with added control.
    PLUS, I would think that there must be some way that Bones would get Displaced with their related geometry. Otherwise they could get quite far away from what they control.
    Seattle
    14,726
    I occurs to me that, for efficiency, the w.maps only need to contain the ONE point in question, not all the points with a value of zero.
    For the sparse structures I'm talking about it's probably not important, but efficiency is always nice.
    May 2014
    Greece
    141
    Try giving all the bones textured motion or nodal motion with a turbulence texture. Also you don't have to assign weight maps, this setup works fine without them. But, as I said before, morphs and displacement would do the job if you want your jittered web to turn into another shape in time and still be displaced.
    Seattle
    14,726
    MG artist, that "texture motion" idea sounds like the ticket!!! Thanks for kick-starting my memory!
    I know the w.maps would be overkill, but it seemed like a good idea at the time, and might be necessary in a much denser mesh.
    I don't think morphs would give me the EASE of a Turbulance procedural displacement.
    For this particular application, moving the Bones with a texture is a viable route (and probably completely sufficient), but I'm still baffled by the mesh moving away from the Bones when displaced. No answer on that one yet.
