Thread: strange deformation when using bones from different object then itself in LW11.6.2
    Hello Guys,
    I noticed this strange behaviour when I try using bones from another object.
    I just quickly created a NULL then added a few bones to it
    Then I try to use these bones from another object. Okey, I go this Object's Bone panel, I select from the dropdown menu Use Bones From Object:NULL.
    And it doesn't deform my Object properly. But if I reparent the bone chain under the Object from the NULL then it works. I guess this is a bug in LW 11.6.2.
    Can anyone else confirm this same issue?
    Can you post a test scene?
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    The setup works if your Skeleton Null is at the origin.
    Attached Files Attached Files
    www.ernestpchan.com
    Thanks!
