Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: point and poly info inlayout
    hello all is there a way to get infomation about each point and polygon in layout
    i am working on a custom exporter and need this info to output in my file
    i have read the docs and there doesnt seem to be a real clear answer to this question
    it looks like the only way to get that info is in modler but i need to export animation data as well
    any suggestions
    Re: point and poly info inlayout
    any suggestions
    point and polygon info can be accessed using the Mesh Object Agent. you need to cycle through all the meshes in your scene. quite easy:
    Code:
    m = Mesh();
    while(m)
    m = m.next();
    // process mesh
    look at the points and polygons object agent in the docs to find out more about the specific type of point / poly info you can access.
    thank you for the reply
    i have gotten the mesh object setup and can get the data mebers in it
    i just wasnt sure on how to setup the point and poly objects
    when i tried setting them up the same as the mesh objects i get errors
    just wanted to double check to make sure it can be done
    now i know it is just me
    hehe
    Well, there is a tool plug-in (not sure if it's a script) called xTool that will let you animate individual points in Layout so it can be done.
    hmm ill have to look into that
    maybe i am just confussed about how it is done
    according to the docs you have to put your script into mesh edit mode but then they say that you can only enter mesh edit mode in modeler
    unless i have to set the script up as a different type or something not sure
    what i need to get is all the points locations and uv data as well as all the poly locations and weightmap data
    i am trying to make a custom model and animation exporter
    dont have much time to sift through this code i did for BoneLatticeGN but this is how i go through points. btw: in this code i go through a mesh's points and look for their endomorphs.
    Code:
    	for(i=1;i<=pointList.size();i++)
    		if(i > selected.pointCount(1))
    			break;
    		j = pointList[i];
    		vmap = VMap(VMWEIGHT);
    		mmap = VMap(VMMORPH);
    		sp = selected.points[j];
    		vec[i] = selected.position(sp);
    		names[i] = nil;
    		values[i] = nil;
    		while(vmap && vmap.type == VMWEIGHT)
    			if(vmap.isMapped(sp))
    				names[i] = vmap.name;
    				values[i] = vmap.getValue(sp,1);
    				break;
    			vmap = vmap.next();
    		j = 1;
    		while(mmap && mmap.type == VMMORPH)
    			if(mmap.isMapped(sp))
    				mmap.getValue(sp);
    				evtemp = <this[1],this[2],this[3]>;
    				endoVal[i,j] = evtemp;
    			mmap = mmap.next();
    			j++;
    btw: the array pointList[] contains integers corresponding to the element it is on.
    pointList[1] = 1;
    pointList[2] = 2;
    pointList[3] = 3;
    etc...
    San Antonio, Texas, USA
    13,054
    I really wish you'd comment your code so dummos like me can learn from the master!
    Not so much the syntax, that's easy to read but what the code is doing and why!
    UI / UX Designer @ NewTek
    thank you very much that will help a lot
    as far as the script running in layout
    did you right it as a generic script or a displacment or something else
    i think that might be where i am having problem so far i have only tried a generic script
    ohh wait
    BoneLatticeGN GN = generic script nm
    nice website btw
    had a question for you faulknermano
    as far as accessing the pointlist array is that setup automaticlly or did you create the array
    and if it is an automatic data you can get to
    is it an object like a mesh object or a data meber of something
    ok maybe im just stupid or something
    but i cant find anywhere in the ref docs anything about the pointList[] array
    there is a point[] array but cant access that in layout only in modeler
    accroding to the docs and i have tried a few things and cant seem to get and info on points or polys in layout other then teh total count
    sorry for keeping you wait: the pointList is created manually, using a loop.
    actually, i use the pointList[] array because of the innerworkings of the original script. the idea is the feed an index number to the points array _data member_.
    if you could try to post your working code snippet i might be able to spot what's going on.
    i was in deep meditation when i was writing it. writing comments sometimes just slows down the thought processes. of course, it's just as hard on me as it is to you on what it all means after a few months.
    oki figured out that the pointList array was made by you
    but as far as geting to the Points array data member how is that done in layout
    i thought you could only get to that from modler scipt inbwteen the editBegin and editEnd calls
