Thread: Loading an image map?
    Jun 2005
    Reading UK
    3,131
    Does anyone know how to load an image map into the image editor with python?
    I'm trying create a simple modelling script, and would like to apply some textures to it.
    i7 X3930/32GB/Quadro 4000
    Code:
    ## Given a string ("p") containing a file path to an image, the following
    ## attempts to load that image into the Image Editor. It then
    ## returns the name of that image and the image ID.
    def loadImage(p):
        IM = lwsdk.LWImageList()
        id = IM.load(p)
        name = IM.name(id)
        return name, id
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    Jun 2005
    Reading UK
    3,131
    Awesome - thanks Ernie! Will give this a try tomorrow.
    Celshader would really be the one to thank. I just passed along what I found.
    www.ernestpchan.com
    Jun 2005
    Reading UK
    3,131
    In that case 'Thanks Celshader!'
    If I can put together anything that works and is useful, from the information I've been given here and elsewhere, I'll be sure to share it.
    Jun 2005
    Reading UK
    3,131
    Got a bit stuck again with this. The code snippet worked fine for loading a texture (although I need to find a better path reference than an explicit one - problem for later). Now what I've been trying to figure out is how to set that image in the surface. The functions I have are:
    def loadImage(self,p):
    id = IM.load(p)
    name = IM.name(id)
    return name, id
    def setTex (self):
    statefunc = lwsdk.LWStateQueryFuncs()
    objname = statefunc.object()
    surf_func = lwsdk.LWSurfaceFuncs()
    surf = surf_func.byObject(objname)
    texfunc = lwsdk.LWTextureFuncs()
    #print(surf)
    texture = surf_func.getTex(surf[0],lwsdk.SURF_COLR)
    texfunc.layerAdd(texture,lwsdk.TLT_IMAGE)
    #print(texture)
    However my setTex one crashes modeller, because the getTex method is returning 'None' as an ID. I assume this is because is trying to read an active 'T' button in the surface editor? And of course I currently don't have one of those. I looked at the SDK for LWTextureFuncs and I can see there is a 'create' method. But that seems to be if you were trying to use a texture directly within the plugin, where as I want to create one in the main surface editor. Any ideas?
