Thread: How do you run a Bullet Simulation with Parented Objects?
    Sep 2003
    Washington DC
    3,618
    Hey guys,
    I wanted to pick you brains.
    I am running a test, to see the limits od a LW bullet simulation using a shopping cart.
    I know that it sounds silly, but I was trying to see if it is possible to have a simulation
    of a dropping shopping cart that mad some cool secondary motions cased by the fall.
    And by secondary motion I mean the cart wheels, and the cart lip.
    (see image attachment)
    I am looking forward to your suggestions.
    -R
    This message does not reflect the opinions of the US Government, CG Networks or CGTALK.com. The opinions expressed on this posting are on my own volition.
    I haven't used Bullet much but why would you need to parent anything in this case? If the cart lip and the wheel are built to be physically accurate, wouldn't collision keep them "connected" to the cart? Just like with a chain simulation, you don't need to parent the chain links to one another because collision stops them from leaving the chain since then are each made of closed interlocking loops.
    -Joshua Jorgensen
    Sep 2003
    Washington DC
    3,618
    I am trying to keep the motion setup limits that I have for the preanted object to have more control of the simulation. And even whith an accurate non parented model, I am having a ton of issues with the part of the object staying on.
    EDITED
    I have post a test render
    -R
