Page 5 of 5 FirstFirst ... 345
Results 61 to 72 of 72
Thread: Lscript Question
  1. #61
    Super Member Kryslin's Avatar
    Feb 2009
    Prescott, IA
    1,459
    Ok, another question...
    Both selPoint() and selPolygon() have a minor parameter of POINTNDX and POLYNDX, respectively.
    What is this? What array am I supplying indices to the selection command? Is this global, or relative to the selection I may be working with? I'm more curious than anything...
    I mean, I get POINTID and POLYID, and I normally use these all the time, inside an editbegin() and editend() pair. So what are these poly and point indices?
    My Scripts for Lightwave
  2. #62
    I believe is it the id of the point/polygon. I would assume it's global to the model since ids don't change dynamically.
    www.ernestpchan.com
    www.zazzle.com/gopuggo
  3. #63
    7,884
    Points can be identified by index (starting from 0..point_count-1) or by LWPntID pointer.
    Polygons can be identified by index (starting from 0...poly_count-1) or by LWPolID pointer.
    If you have address (i.e. outside of 0..count-1) it's the second one.
  4. #64
    San Antonio, Texas, USA
    13,054
    Post
    This is not an exhaustive list, but this is a scratch pad of some poly / point stuff (it's not a script you can run as is, just a collection of stuff) that I kept lying around, might help.
    Code:
    @version 2.13
    @warnings
    @name "Point and Polygon Routines"
    main
        // Selected including nothing selected = all selected rule
        selmode( USER );
        // Direct selections only
        selmode(DIRECT);
        // Selected everything regardless of selection
        selmode( GLOBAL );
        // 0 = Point / 1 = Poly / 2 = Volume / 3 = Edge
        selection_mode = getmode("SELECTION");
        // 0 = Off / 1 = On
        symmetry_mode = getmode("SYMMETRY");
        // 0 = Mouse / 1 = Pivot / 2 = Selection / 3 = Pivot
        action_center_mode = getmode("ACTIONCENTER");
        // Get the point count
        point_count = pointcount();
        // Need minimum of two points
        if(point_count < 2)
            error("You need to select at least 2 points");
        // Get selected poly information
        selectedPolys = polycount();
        // Total number of selected polygons
        selectedTotalPolys = selectedPolys[1];
        // Total number of selected polygons with 1 point
        selected1PointPolys = selectedPolys[2];
        // Total number of selected polygons with 2 points
        selected2PointPolys = selectedPolys[3];
        // Total number of selected polygons with 3 points
        selected3PointPolys = selectedPolys[4];
        // Total number of selected polygons with 4 points
        selected4PointPolys = selectedPolys[5];
        // Total number of selected polygons more than 4 points
        selectedMoreThan4PointPolys = selectedPolys[6];
        // Storing polygon information
        var polyIDs         = nil;
        var polyTypes       = nil;
        var polyPartTags    = nil;
        editbegin();
        foreach(poly, polygons)
            polyIDs         += poly;
            polyTypes       += poly.type();
            polyPartTags    += poly.tag("PART");
        editend();
    @script modeler
    @warnings
    @name "Part Name"
    main
        selmode(DIRECT);
        selectedItems = polycount();
        if(selectedItems[1] == 0)
            error("Nothing Selected");
        editbegin();
            for(loop = 1; loop <= selectedItems[1]; loop++)
                partName = polygons[loop].tag("PART");
                info("Part Name: ", partName);
        editend();
        // Inspecting polygon information
        var polyNumber = 1;
        editbegin();
        // Get ID of polygon
        polyID              = polygons[polyNumber];
        // Number of points that make up the poly
        numPointsInPoly     = polypointcount( polygons[polyNumber] );
        // The vector for the poly normal
        polyNormal          = polynormal( polygons[polyNumber] );
        // Get the surface assigned to the poly
        polyInformation     = polyinfo( polygons[polyNumber] );
        polySurface         = polyInformation[1];
        // Store point IDs and positions for polygon
        // Starts at 2 because the surface name is the first entry in the array that polyinfo() returns
        // Every entry in the array after that is the point ID
        for(loop = 2; loop <= numPointsInPoly; loop++)
            polyPointIDArray    += polyInformation[loop];
            // Point into gets the points XYZ location
            polyPointPosArray   += pointinfo(polyInformation[loop]);
        editend();
        // Selecting and deselecting poly selections
        // Select a poly by its ID
        selpolygon( SET, POLYID, polyIDs[1] );
        // Select all polys by their ID using a custom function
        select_poly_ids( polyIDs );
        // Select all polys
        selpolygon( SET );
        // Deselect a poly by its ID
        selpolygon( CLEAR, POLYID, polyIDs[1] );
        // Deselect all polys by their ID using a custom function
        deselect_poly_ids( polyIDs );
        // Clear all polys
        selpolygon( CLEAR );
        // Invert selections
        selinvert();
        // Hiding selected polys
        selhide( SELECTED  );
        // Hiding unselected polys
        selhide( UNSELECTED  );
        // Unhiding hidden polys
        selunhide();
        // Selecting and deselecting point selections
        // Select a point by its ID
        selpoint( SET, POLYID, polyPointIDArray[1] );
        // Select all points by their ID using a custom function
        select_point_ids( polyPointIDArray );
        selpoint( SET );
        // Deselect a point by its ID
        selpoint( CLEAR, POINTID, polyPointIDArray[1] );
        // Deselect all points by their ID using a custom function
        deselect_point_ids( polyPointIDArray );
        // Clear all points
        selpoint( CLEAR );
    select_poly_ids: polyIDArray
        for(loop = 1; loop <= polyIDArray.size(); loop++)
            selpolygon( SET, POLYID, polyIDArray[loop] );
    deselect_poly_ids: polyIDArray
            selpolygon( CLEAR, POLYID, polyIDArray[loop] );
    select_point_ids: pointIDArray
        for(loop = 1; loop <= pointIDArray.size(); loop++)
            selpoint( SET, POINTID, pointIDArray[loop] );
    deselect_point_ids: pointIDArray
            selpoint( CLEAR, POINTID, pointIDArray[loop] );
    UI / UX Designer @ NewTek
  5. #65
    Feb 2009
    Prescott, IA
    1,459
    Matt: handy stuff, that.
    Re: getmode("SYMMETRY"); ... is there an equivalent to set / toggle the symmetry mode?
    Still, regards to the indices question... where are those indices coming from, what are they referencing? This looks like something that will require experimentation, which means I have to wait until I can go up and down stairs to get to the work station... I hate recovering from surgery.
  6. #66
    May 2017
    Lampertheim, Germany
    123
    The indices are simply the indices from the Arrays, taht are generated by LScript when you enter the editmode (editbegin).
    By entering the editmode in LScript, the engine creates 2 Arrays.
    1 named "polygons" and one named "points". The indices are simply the index of an element in these Arrays.
    I hope this will help.
    Regards
    KANUSO
  7. #67
    Feb 2009
    Prescott, IA
    1,459
    Here's an interesting one...
    Is it possible to read a bone's weightmap in lscript? It appears you can set one - BoneWeightMapName("name"); - but I don't see anything that looks like you can read the name of the weight map...
    Here's why I'm asking : I have a tool, that assigns weight maps symmetrically, giving identifiers for Right and Left for bones and weight maps. My last revision had added buttons to move up and down the hierarchy, and assign & move to the next bone. I want to add "Next Unassigned" to the buttons, so that you can move to the next bone that doesn't have a weight map assigned to it.
    If it isn't possible, then I have another candidate for conversion to Python.
  8. #68
    San Jose, CA
    6,470
    Possibly mitigated since, but according to this thread, in 2006 Dodgy was asking Newtek to fix lack of read access to that info (as well as some other important info access issues).
    John W.
  9. #69
    7,884
    In Python it's possible to get weight map assigned to specified bone using Bone Info.
    sdk/lwpython2015.3.zip/python2015/globalboneinfo.html
  10. #70
    Feb 2009
    Prescott, IA
    1,459
    JWeide: From what I can tell, based on going through the lscript release docs, It hasn't been added. However, until someone from Newtek comes up and says "Hey, its there, here's a code snippet..." then I'm off to Python...
    Sensei : Yeah, I saw that in the Python SDK docs. Looks like I'm moving my Weight assignment tool over to Python...
  11. #71
    San Jose, CA
    6,470
    Python approach is direct, might as well use it.
    John W.
  12. #72
    Feb 2009
    Prescott, IA
    1,459
    Ack, phbbbbt, never mind, question answered up thread.
    Last edited by Kryslin; 10-25-2018 at 02:26 PM. Reason: Questiuon Answered in previous posting...
