Results 1 to 15 of 21
Thread: Free Script: Split Frame
    San Antonio, Texas, USA
    13,054
    Post Free Script: Split Frame
    Someone was needing this, which had been done before, but as a .p plugin, and was only 32bit. I could have sworn there was already an LScript that did the same thing, but I couldn't find it, so thought what the heck and wrote it anyway.
    Split_Frame_v1.0.zip
    What does it do?
    It takes the currently loaded scene and saves out multiple scenes based on the number of columns and rows, setting the Limited Region render property for each one. You can also specify an overlap margin. For when you need to do massive renders that can't be rendered in one go, or you want to spread the rendering load of one frame over many machines using ScreamerNet.
    Hope you find it useful. As always, the LScript code is commented for those wanting to learn it.
    Cheers
    Matt
    UI / UX Designer @ NewTek
    Dec 2004
    San Juan Island
    4,686
    Cool. These are all completely separate scenes? Can it be done with separate cameras?
    13,054
    Quote Originally Posted by spherical View Post
    Yes separate scenes, but I could make it possible to split out cameras to different scenes with each camera being active - good idea!
    Dec 2004
    San Juan Island
    4,686
    Yes. Was remembering a plug or script that would load cameras in sequence. Combining the two, you could render a huge pixel dimension file while sleeping.
    What about having one camera that animates to make the tiles.
    www.ernestpchan.com
    www.zazzle.com/gopuggo
    13,054
    Post v1.1
    Okay, try this, lemme know if it works for you.
    Split_Frame_v1.1.zip
    Heffalump
    Away
    3,897
    Heh. I had to do the same thing in the last couple of days to get a massive ground plane texture out of Vue for use elsewhere. This will be pushed into tiled EXRs, but rendering with xStream through LW was just a ridiculous endeavor due to the amount of time required (although it was kind of neat to see the camera stepping across the terrain. Therapeutic.)
    It shouldn't be too hard to generate a script to do this, though.
    Inactive.
    I made a script for AE that does this when I had to deal with generating print res files from Flash swfs so the technique definitely has its place.
    www.ernestpchan.com
    Dec 2004
    San Juan Island
    4,686
    As long as the camera doesn't move....
    Dec 2004
    San Juan Island
    4,686
    Quote Originally Posted by Matt View Post
    Thanks, Matt. I'll check it out first thing. I've been up for a little over two days, now, so wouldn't be the best tester on the planet, ATM.
    Nice!
    Kev xx
    Dec 2004
    San Juan Island
    4,686
    Thanks. No, that's not what I meant. I was a bit confused when the settings greyed out with "Cameras" selected. What you have is scenes are saved with each camera that was in the original scene selected in sequence in each scene copy. What I meant was one scene is saved with cameras duplicated from the selected camera, each having the Limited Region according to the column row settings. Then, you can load cameras in sequence to render out the tiles.
    Thought I may have found a way to get what I'm looking for but it doesn't work like I thought. I figured that I could just Load Items From Scene and get each of the cameras. Problem is, the Limited Region of each doesn't come in with the camera. Evidently, it is saved in the scene.
    The other thing that was unexpected is that the camera position when loaded in changes. Complicating matters, the camera in the original scene is parented to a null. The loaded-in camera rotated clockwise around the null by the amount that the null is rotated. Parenting to the null and adjusting the H corrected that but the position remained incorrect; pointing the right way but still in the place that it rotated to. Would have to copy/paste the X/Z values to reposition.
    But, there is only one Limited Region available in a scene, so my approach won't work. Darn! So, I'm not seeing the benefit of version 1.1, I guess.
    Registered User tyrot's Avatar
    Mar 2006
    in lights
    2,162
    can somebody show me how plugin works,,, and also CAN IT WORK WITH OCTANE ! please show me! gotta render 6 K image....
    WOOOW it is working with OCTANE!
    MY GOOOOOOOODNESS - MATT you saved my life!
    this script seems not to work anymore in LW2018 (at least on macOS) - i'm getting "line 61, illegal arithmetic operation on data type".
    matt, could it be somehow upgraded? i see it's an lscript, but sorry i'm not into programming... or is there any better ready solution for LW 2018? for using this with octane it would need to save out separate scenes with cameras set in a way that it would work without limited region. the reason is that octane cannot render 'cropped' regions in LW without needing the whole frame loaded. i guess this is only possible with shift cameras.
    3dworks visual computing
    demo reel on vimeo
    instagram
    there also a version of it in odtools.
