Results 1 to 12 of 12
Thread: Little Help
    Little Help
    Can anyone tell me what causes these sparly looking artifacts (circled in yellow)? I've got anti aliasing set to a middle range and the area lights are set to 10.
    DI
Name:	Surface issue.jpg
    Time is not linear but rather an eternal "now."
    Medical Animator mummyman's Avatar
    Aug 2009
    Connecticut
    1,013
    How is it textured? Can you increase the reflection / refraction samples? or surface samples? Is it a refraction blur quality?
    Hey mummyman, sorry for the delayed response. I'll check your response and re post. I had to launch the render as is to meet the deadline and don't want to stop it. Not a show stopper but something to learn the cause of for the future. Thanks for responding.
    DI
    Axes grinder- Dongle #99
    Seattle
    14,726
    Please include a hint of your problem in the Subject Line of posts-- better responses.
    Praise to Buddha! #resist
    Little Help with render artifacts
    Hmm, good point.
    Old Dog Learns New Tricks RudySchneider's Avatar
    Jan 2006
    Lincoln, CA
    1,307
    If you're using radiosity, do you have Limit Dynamic Range checked?
    There are no problems, only opportunities...
    Quote Originally Posted by RudySchneider View Post
    I have to wait for the current frame to finish. Should it not be if it is (LDR)?
    DI
    Jan 2006
    Lincoln, CA
    1,307
    I have renders that exhibited similar (if not identical) artifacts when Limit Dynamic Range was unchecked. Though, I suppose it may be attributed to the HDR image I was using as a radiosity background.
    Just figured I'd throw it in the ring and see where it lands...
    I have renders that exhibited similar (if not identical) artifacts when Limit Dynamic Range was unchecked. Just figured I'd throw it in the ring and see where it lands...
    Thanks, I just shut down the render to check. At this point in "might be" the wrong thing to do in case there's a hit in the look. I'll do a test though so I know for future reference. Thanks.
    DI
    Yes it was unchecked. I checked it and am running a test. Thanks.
    DI
    I'll be damned, that was it. I owe you a beer. Thanks Rudy! There's a pretty good explanation why in this LW e-book on Pg. 263
    http://books.google.com/books?id=o0o...0range&f=false
    Thanks Again! You Rock!
    DI
    Jan 2006
    Lincoln, CA
    1,307
    Glad I could help. It doesn't happen often, but (I recall madno on one of the other threads saying) "even a blind squirrel finds a nut once in a while."
