Page 1 of 16 12311 ... LastLast
Results 1 to 15 of 229
Thread: Modeler - Fixes / Updates
    Fixes >
    Knife tool, fix
    http://youtu.be/-fNARSQIgLA
    Drag Network Tool, fix
    http://youtu.be/VZ4pRP9qukg
    Junk, Border Points, fix
    http://youtu.be/FxV08wTQzCY
    Junk, Weld / Merge, fix
    http://youtu.be/RlzJwocco24
    Send Layers to Layout, fix
    http://youtu.be/1crpvJ41RyI
    Deselecting, fix
    http://youtu.be/jxivcuN52QA
    Remove Edges
    http://youtu.be/JLjxyLDXfHU
    Tube, Speed
    http://youtu.be/Wes4GhF_owA
    Bend Tool
    http://youtu.be/H6u2y1h676M
    Tweak, update
    http://youtu.be/eOaLSYaPB80
    Edit Edges, update
    http://youtu.be/4puCBEIKu-0
    LineUpPointsEQ
    http://youtu.be/E3idszpSNjc
    Airbrush Normal Move
    http://youtu.be/oPUkCJ_kC3I
    Layers - misc tools
    https://www.youtube.com/watch?v=q39zGeDq6yY
    https://www.youtube.com/watch?v=J3RpXok2YfE
    https://www.youtube.com/watch?v=fKJJOJlaUfw
    https://www.youtube.com/watch?v=tSFsJyRDbaM
    +Update Rounder
    +Undo / Redo selections
    Unigon
    http://youtu.be/COarf-Nlw0A
    Edge Relax
    http://youtu.be/Hx5b0Z4XnXE
    Mezure
    http://youtu.be/YuduhI-oZj8
    SplineLength
    http://youtu.be/tH-NV8W5Gok
    PX Arc
    https://www.youtube.com/watch?v=EwFbBnCiRkE
    JetoFillet
    https://www.youtube.com/watch?v=F3lwSIraIQs
    RailPoly / WeldStrip
    https://www.youtube.com/watch?v=vVCV1ZXLKzM
    3DD MeshRekniter (32)
    http://youtu.be/7_ISeyMKc_A
    makes the impossible possible...
    http://www.youtube.com/watch?v=c_uLcNvGz6U
    Bevel++
    http://youtu.be/AMiXbMHPDoM
    Updates > Realtime Tools
    Rest on Ground
    Boolean (LWCAD primitive mode only)
    Cut Tool
    Julienne (MG Julienne 3D)
    Array (LWCAD)
    Smooth (cp Realtime Smooth)
    Jitter (cp Realtime Smooth)
    San Antonio, Texas, USA
    13,054
    Can you FogBugz this also Erik.
    UI / UX Designer @ NewTek
    ok, will FogBugz it...
    (not right now though, took me hours just to make the list) \:O
    This is where the Fogbugz falls down. Erikals details all these points with direct visual audio communication, as if sitting there showing the coders what isn't working, and then he's required to sit down and write it all up in words that can be misinterpreted. I think he's done enough, it takes a lot of time to record these examples. There needs to be an alternative option to communicate this feedback to the development team, I really think these videos are the best most direct method of communication in some cases. Can he just link to the videos in a Fogbugz report, I dunno?
    I wouldn't think he'd need to do much more than write a 1-2 sentence summary of what the videos are explaining, paste the links, and the devs end up with a proper "report" in a centralized location that is easier to readily access than these forums. At least, that's what I think is the mindset of devs is when they ask people to fogbugz feature requests if they have good and detailed input to provide like Erikals often does.
    Quote Originally Posted by chazriker View Post
    If he can put up the links in a report then that should be fine.
    re tube speed:
    over in 3dsmax for a comparison:
    stee+cat
    real name: steve gilbert
    http://www.cresshead.com/
    Q - How many polys?
    A - All of them!
    Dec 2004
    San Juan Island
    4,686
    Quote Originally Posted by djwaterman View Post
    I've referenced and linked entire threads in the 9.x Beta forum during that program, sometimes adding a query string to direct the devs to a more pertinent sections of them, so they don't waste a bunch of time slogging through a whole thread.
    having made this list, still BIG thank you for solving these past challenges >
    the ones that have an (X) - http://www.youtube.com/user/erikalst...?query=%28X%29
    14,693
    Canīt tell for sure, but the dev team has stated how inspirational erikals clips has been for them, and probably helpful for the development, so I think they indeed have an eye on what he putīs up...at least several of the guys should have a prescription on his youtube channel to make sure not to miss it.
    Michael
    14,693
    erikals...I donīt quite follow what you mean in the fix the tweak tool and points, with the tweak tool you can just as with polyselection pick a point and hold shift and move it in the normal direction, so
    Im not clear on what you mean on that?
    Regarding enhancements to it..
    Faster initialization of the tool...a bit too slow I think.
    I think the tweak tool should have a boost since it is limited by selecting only one polygon or point, shortcut control shift or alt maybe that allows for multiselect of polygons and move and also extend faces would mean a lot for a much better workflow.
    Michael
    yes / no
    it moves in the normal, but i want it to slide on the edge and stretch on the edge
    these explain it better >
    StretchPoint > http://www.youtube.com/watch?v=zozJ7trpEUg
    WedgeSlide > http://www.youtube.com/watch?v=pzr7uUHC0xs
    snapping would also be welcome for both of these, and the transform tool as well i guess
    tested an AHK script to get rid of junk geometry, might give LW programers an idea... >
    http://forums.newtek.com/showthread....-Merge-Janitor
    (i'll try to follow up on these Modeler challenges, suggest further improvements)
    one more thing >
    Layout Selection Error, Fix
    http://youtu.be/BaUtekAXJoU
