Thread: Problems with Analog audio in 4 channel redundant mode on 3play 4800
    Sep 2013
    New Zealand
    6
    I wonder if anyone else has come across this problem??
    In the standard 8 channel mode i had 8 SDI inputs with Analog audio selected and working fine.
    But then when i booted the 3Play up in the redundant mode it gave me no option to select analog audio - only the SDI embedded option was available.
    Weird.
    Any ideas?
    Sep 2005
    NewTek
    1,656
    Can you post a screen shot of the audio dropdown on the input panel?
    Zane Condren
    NewTek Inc.
    new.tk/call
    19,080
    There really shouldn't be a problem. I wonder if it's simply that you had enabled recording already. That would prevent you from making changes to the audio source.
    Sep 2013
    New Zealand
    6
    I'll have to see if it occurs again on the next gig to get you a screen shot. I was just inquiring to see if anyone else had had a similar problem. I hadn't begun recording at that point. On the night i switched back to 8 channel and it worked fine.
    Nov 2013
    New Zealand
    7
    I later opened the session discussed above and was unable to recreate the issue - either with the existing session or creating a new session - the audio selection behaved as expected.
    However, we have had other issues related to audio - I'll post in a separate thread.
    Mark
