Results 1 to 15 of 18
Thread: SSS Glow at Intersection of 2 Objects
    Apr 2006
    Melbourne, Australia
    287
    Here are a couple of boxes, one with Simple Skin added. When the smaller box touches the bigger one, the area of contact immediately illuminates. If the bigger box is set to Double Sided, the problem goes away. If reflection is turned up on the smaller box, it's back again! Any idea what's going on (and more importantly, how to stop it)?
    SSS_Intersection_Glow.zip
    Thanks,
    (c:
    Vacant, pretty vacant pinkmouse's Avatar
    South Yorkshire
    1,700
    SSS expects a closed mesh, and I suspect that interpolating other geometry confuses the shader. Have you tried booleaning the intersection out?
    Al
    "I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while." Charles Fort
    My Website
    My Lightwave Tutorials
    Nov 2003
    jersey
    5,763
    Thats just how it is with SSS, penetrations/intersections cause this owing to the "internalised" shading.
    RHA Animation Tutorials
    RHR Rigging Tutorials
    RHN Nodal Tutorials
    YT Vids Tuts for all
    Apr 2006
    287
    Hmm.. well that seems like somewhat of an oversight, since reflective and SSS surfaces would come into contact with one another quite commonly I'd have thought. Take humans and animals for example...
    Nov 2003
    jersey
    5,763
    Its not an oversight... its just one of the problems inherent in SSS shading methods, you see other kinda artifacts in other renderers in the same sorta situations. The only real fix for it is to use an AO shader to "detect" proximity of geo and use that to mask the depth shading effect.
    RHN Nodal Tutorials
    Dec 2004
    San Juan Island
    4,686
    So, you have a microscopic air gap between the two; instead of actually touching. Which, btw, is the case in reality. There is always some air between objects that are not actually part of one another. If there weren't, they would actually stick together.
    Apr 2006
    287
    Would it be safe to call it a bug then...? Seems rather odd that the reflectivity of one object would have such an effect on the SSS of another, as the two objects happily intersect otherwise without adversely affecting the SSS. That AO solution sounds tricky... I shall look into it, thanks.
    Quote Originally Posted by spherical View Post
    Yes I realise this, but when you have a number of morphs, bones, effectors and things working together to slide one object over the other (as in an eyelid), maintaining a consistent, indiscernable gap is far more difficult than having a small amount of overlap.
    (c:
    Nov 2003
    jersey
    5,763
    Quote Originally Posted by Chris Jones View Post
    No... its just the way it is... Intersections WILL cause SSS shading errors. In some simple setups, with certain lighting conditions (which are really just special cases) then the double sided can appear to fix things, but in a lot of situations it wont.
    RHN Nodal Tutorials
    cloning the object and use a clip map might be a way to solve it?
    not quite sure, but maybe...
    Attached Files Attached Files
    could this be a solution for the close-ups...?
    seems to work here... (running LightWave 11.6)
    Apr 2006
    287
    Unless I'm misunderstanding, I don't think clip maps would work for spherical or organic shaped objects..?
    Double sided only works if both objects are SSS unfortunately.
    clip maps work with UV mapping, so i think it should work. (time-consuming though...)
    looks to work here >
    Apr 2006
    287
    That's very weird... I tried it earlier and it definitely didn't work. Tried it again just now and it does. Is there a special practical joke version of LW? Because I think that's the one I have...
    Thanks for the tips, I'll see if I can get them to work in practice.
    so there is a random bug here? right?...
    Registered User Lucasmorif's Avatar
    Oct 2013
    Brazil
    66
    I had this similar problem with an eye intersection once, didn't know how to solved it and ended up abandoning the SSS.
    Looking forward for a solution.
