Thread: Why is my reflection blurring so speckly?
    Jun 2013
    Abq
    60
    I want a slightly blurry reflection but when I turn reflection blurring on it makes it look speckly. Does anyone know a fix for this? Thanks!
    Up the shading samples in the render tab of the render globals pannel.
    Pessac
    5,034
    And/or increase your max samples.
    B
    LightWave 3D Trial Edition
    Aug 2010
    Kernow
    2,057
    I've found that if you create a copy of your texture environment and really blur it and then use the blurred version as your spherical reflection image you can get a noise free blurry reflection.
    It's not quite right as any actual item that's reflected comes out quite sharp, but on the whole it looks good.
    Top tube = reflection, no blur.
    middle tube = reflection with 15% blur.
    bottom tube = spherical reflection map(blurred environment texture map) + raytrace.
    No of samples 32.
