Results 1 to 11 of 11
Thread: Reflection blur rendering faster in 11.5 vs 10.x ?
    I recently decided to use the standard reflection blur found under the Environment tab in a rendering. I never used to use it much because it really bogged down rendering. It now seems to render very fast in 11.5 compared to the 10.x and 9.x series. When I render in Modo I use reflection blur all the time because it renders fast and now it seems I can do the same in Lightwave without having to worry much about long render times!
    Is reflection blur faster because of the new unified sampling?
    The shading samples default to 1 on 11.5+ The default used to be higher I beleive. But reflection bluring did get a revision at one point, because it does seem to render faster and definitely looks better than before.
    I cranked up the shading samples to 8 and it still renders really fast compared to before.
    Time Traveller Andy Webb's Avatar
    Hertfordshire UK
    2,154
    I noticed this too. I have been using it much more lately because of the speed up.
    Andy Webb
    Intel core i7-3820 3.60GHz
    Asus P9X79 Deluxe motherboard
    GeForce GTX 660
    32 Gb RAM
    Windows 10
    Quote Originally Posted by Nicolas Jordan View Post
    Yup... Still could be improved on sampling spread levels when going through AA but 99% better than it was on 10.x and below.. On the average I usually use the range of 4-12%... Course you could nodal it and produce some great results also and just plug it into the refection channel.
    -M
    I was thinking of the immortal words of Socrates - "I Drank What??"
    7,876
    v10.x has no unified sampling.
    So what do you expect?
    Old refection blur is sending multiple ray-tracing calls per single spot. Then the next bounce, it's repeating again, and again. Until reaching Ray Recursion Limit.
    Remember that you can enable cache in reflection/refraction node.
    Just curious what's the best way to set up a subtle reflection blur on a surface like plastic using nodes?
    I tried the Reflection node but it seems to automatically cause a strong reflection with only the ability to control the amount of blur.
    North Carolina
    11,398
    put a scale node into the green reflection slot with a value of 2 or 3 or just turn down the reflection in the classic editor. Yes, I know it's wierd how the reflection shading slot doesn't handle reflection amount.
    Using a fresnel gradient helps realism control the reflection amount helps too.
    Quote Originally Posted by jasonwestmas View Post
    Thanks for the help Jason that seems to work nicely.
    London
    2,323
    I've always avoided it until recently, as well, so really happy it's now a lot quicker.
    I cant remember the full technical description (and i cant find it either!) but there's a node setup that can be used that cuts the reflection blur after one ray bounce. Would be interested to hear if its needed anymore or if its quick enough now without it. Anyone tried?
    7,876
    Quote Originally Posted by raw-m View Post
    I showed how to do it in mine video tutorials
    http://www.youtube.com/watch?v=WjvUxRnNcak
    http://www.youtube.com/watch?v=nP425jM1oGM
